Dauntless
I am looking for information about the Aero-Dynamics LTD "Sparrow Hawk" of the mid-80's. Anybody know anything about it, or whether the design morphed into the Sadler Vampire?
Thanks! Stan
Thanks! Stan
Even though such a configuration can somewhat obscure the downward vision of the persons on board, I agree that this is probably the best solution for a two-seater. I have flown a variety of tandem airplanes, and none of them are much fun for the back seater.Why is it a mid wing? Wouldn't a low wing enable you to put the wing further forward and thus enable putting the passengers very close to the center of gravity? Would it then have too rear CG problems with the engine placement? Putting the battery at the nose wouldn't compensate?
Yeah. It's hard to compensate for 200# of passenger with 25# of battery, even if its a couple of feet farther forward.Why is it a mid wing? Wouldn't a low wing enable you to put the wing further forward and thus enable putting the passengers very close to the center of gravity? Would it then have too rear CG problems with the engine placement? Putting the battery at the nose wouldn't compensate?
water could be used for ballast, is readily available most anywhere, and can be dumped if not needed.- ballast -
And you can't leave it behind anywhere. What if, on the other end, you want to take a quick flight in the configuration that needs ballast? Or fly somewhere with a passenger and then return solo? The ballast needs to be accommodated in two positions in the airframe to accommodate the likely crew/fuel/baggage scenarios, which means it's always there, sucking performance.
Could be. Can you count on every Joe that buys the plane to fill or empty the water tanks appropriately for every flight in the thirty-to-fifty year life of the airplane, when most of them only do a W&B for their Practical or a really picky biannual? And what do you do if the airport at East Podunk has a broken faucet, and you have to leave solo?
