Decalage angle
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by Eugene, May 29, 2017.
  1. Jun 13, 2019 #1041
    poormansairforce
    poormansairforce
    poormansairforce
    Mar 28, 2017
    700
    197
    Just an Ohioan
    Mike Arnold talks about this pressure recovery on his AR-5 and not losing airspeed in a turn.
  2. Jun 14, 2019 #1042
    Eugene
    Eugene
    Eugene
    May 26, 2017
    845
    155
    Merrill, Wisconsin, USA
  3. Jun 14, 2019 #1043
    Eugene
    Eugene
    Eugene
    May 26, 2017
    845
    155
  4. Jun 14, 2019 #1044
    Eugene
    Eugene
    Eugene
    May 26, 2017
    845
    155
    Hopefully I got it right this time
  5. Jun 14, 2019 #1045
    Doggzilla
    Doggzilla
    Doggzilla
    Jun 2, 2013
    2,060
    439
    Everywhere USA
    Looks good so far. How are you considering constructing it?
    I would probably cover the aircraft in plastic and use foam to sculpt the new shape, then create a cast by placing plastic on it and laying more foam to make a negative/cast.
    But that is not my area of expertise and Im sure some of the other members can give more detailed and accurate instructions, quite a few of them have made entire aircraft using foam and casts before.
  6. Jun 14, 2019 #1046
    Doggzilla
    Doggzilla
    Doggzilla
    Jun 2, 2013
    2,060
    439
    Everywhere USA
    Yes, that looks much better than my sleep deprived drawings in MS Paint.
    With a little practice you should easily be able to create a cowling. The real question is how you want to attach it. Forward hinges? Forward sliding rails like a cabinet? Or sideways (but this can interfere with access to the other side).
  7. Jun 14, 2019 #1047
    Eugene
    Eugene
    Eugene
    May 26, 2017
    845
    155
    For some reason building was never problem for me, but to find correct shape is not easy at all.
    From what I understand every part of your airplane does some kind of work. Some working for you, but some agains you.
    No matter how hard I try bottom of my fuselage still will have 8-10° angle in level flight
  8. Jun 15, 2019 #1048
    Eugene
    Eugene
    Eugene
    May 26, 2017
    845
    155
  9. Jun 15, 2019 #1049
    Eugene
    Eugene
    Eugene
    May 26, 2017
    845
    155
    Looks like they doing the same thing by filling empty pockets behind the wing. So ,I must be moving in right direction.
  10. Jun 15, 2019 #1050
    3,974
    1,167
  11. Jun 16, 2019 #1051
    AdvenJack
    AdvenJack
    AdvenJack
    May 11, 2019
    36
    21
    Florida - Between St. Pete & Weeki Wachee
    Eugene likes this.
  12. Jun 16, 2019 #1052
    plncraze
    plncraze
    plncraze
    May 12, 2006
    1,668
    359
    Robert Cumberford did a report on this plane in a 1975 Air Progress and said the students who built it were underwhelmed by its performance.
  13. Jun 16, 2019 #1053
    Doggzilla
    Doggzilla
    Doggzilla
    Jun 2, 2013
    2,060
    439
    Everywhere USA
    Its 23% faster than the Cessna 152 it took the engine from, which is pretty good.
    Its roughly like comparing a Mooney M20 to a Cessna 172. Its a very impressive increase in performance, but without suffering the limitations of the Mooney.
    I would call that quite successful.
  14. Jun 16, 2019 #1054
    plncraze
    plncraze
    plncraze
    May 12, 2006
    1,668
    359
    IIRC the students who built it had expected even better performance than they got and it was overweight. I wonder if a propeller designed to work in the airflow of the tail would improve it.
  15. Jun 16, 2019 #1055
    12,513
    2,535
  16. Jun 16, 2019 #1056
    Eugene
    Eugene
    Eugene
    May 26, 2017
    845
    155
    I was told this morning that this is correct explanation, but at wrong speed. They think, that this effect is only big enough above 200 km/hr to worry about. Engine cowling at speeds below 100 mph = 160 km/hr on engine sitting on backside of the wing and behind BRS will give you at best 3 mph. It will improve airflow to the prop at 20-30%. That area on your prop not doing much anyway.
    Searay designer tell me same thing - "waste of time and effort with no speed increasing at all"
  17. Jun 16, 2019 #1057
    Eugene
    Eugene
    Eugene
    May 26, 2017
    845
    155
    Anybody know what kind of airplane this is? I can't find it anymore.
  18. Jun 16, 2019 #1058
    plncraze
    plncraze
    plncraze
    May 12, 2006
    1,668
    359
    It looks like a modified Piaggio Avanti. It looks like they fattened out the fuselage to cover the wing out to the nacelles. If you can picture the airflow in front of the props you are probably as baffled as I am to why they did this unless they are just modeling the forward fuselage.
    Eugene likes this.
  19. Jun 16, 2019 #1059
    Eugene
    Eugene
    Eugene
    May 26, 2017
    845
    155
    Its not a canard and only one engine
  20. Jun 16, 2019 #1060
    Eugene
    Eugene
    Eugene
    May 26, 2017
    845
    155
