Decalage angle
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by Eugene, May 29, 2017.
  1. Jun 3, 2019 #981
    Eugene
    Eugene
    Eugene
    May 26, 2017
    596
    109
    Merrill, Wisconsin, USA
    Doggzilla likes this.
  2. Jun 3, 2019 #982
    Eugene
    Eugene
    Eugene
    May 26, 2017
    596
    109
    I do understand the fact that bottom end of my airplane is very wide and draggy. I do understand that all this drag is positioned far below the engine and creating large moment. Large moment creating large balancing losses in the efficiency department.
    Here is my question. What do we know about balancing losses for all those airplanes that fly with floats? Every time I am talking to them, they really are not complaining about anything at all. They do admit that airplane is usually 10 miles an hour slower and need a little bit more nose up trim.
    Some of those floats are relatively huge, with extra weight and so many different cables to support. They must produce much more drag then my lending gear, but that doesn’t seems to bother those airplanes.
  3. Jun 3, 2019 #983
    poormansairforce
    poormansairforce
    poormansairforce
    Mar 28, 2017
    512
    105
    Just an Ohioan
    The floats are fairly streamlined but still a lot drag as you mentioned. Are those planes tractors or pushers?
  4. Jun 3, 2019 #984
    Doggzilla
    Doggzilla
    Doggzilla
    Jun 2, 2013
    1,597
    326
    Everywhere USA
    It's a lot more than that. A Cessna P model with floats is more than 20 knots slower. Almost 30. 123kts down to 94.
    That's why I like the LA-200. Amphibious without any performance reduction compared to aircraft with the same engines. Quite an impressive aircraft.
  5. Jun 3, 2019 #985
    11,405
    2,092
    The balancing trim drag is relatively small. The issue is overall fuselage and engine drag.
    proppastie and Eugene like this.
  6. Jun 3, 2019 #986
    Eugene
    Eugene
    Eugene
    May 26, 2017
    596
    109
    I know local guy with LA-200 . We spend a lot of time talking about trim drag and how much slower this airplane in comparison to different airplanes with the same weight and engine power.
    Yes it is different, unique, capable airplane. But from efficiency stand point it is on the very bottom of the list. He was telling me that if power is removed, nose will go straight up and you can stall this airplane in a matter of a few seconds. That should tell us that this airplane is flying around with tremendous down pressure on horizontal tail. That pressure doesn’t come for free , there is a big penalty in a form of balancing losses .
    There’s a reason why insurance is very high for this machine.
  7. Jun 3, 2019 #987
    Eugene
    Eugene
    Eugene
    May 26, 2017
    596
    109
    Yes, this is what I hear from everybody. There is not one single problem with this airplane, but every little thing is taking away 10% .
    10 times 10% = 100%!!!.
    And fact that most of this problems positioned below engine doesn't help of coarse.
    Someone told me that free falling drop of water have perfect shape, but only for that slow speed. As speed going up this water drop needs to get longer. Do we know how much longer? Is 60 MPH need 3:1 ratio and 100 MPH need 5:1 ?
  8. Jun 3, 2019 #988
    11,405
    2,092
    I don't know what shape a falling rain drop has. But 3:1 ratio is about best for a streamlined body. Shouldn't matter at normal airplane speed at 60 or 100. Might matter at insect size.
    The problem for your high drag aircraft is that double the power doesn't give double the speed.
  9. Jun 3, 2019 #989
    Doggzilla
    Doggzilla
    Doggzilla
    Jun 2, 2013
    1,597
    326
    Everywhere USA
    The LA-200 is the fastest production amphib ever made with an O-360.
    It's over 30 knots faster than the O-360 Cessna 172 amphib.
    I would definitely not say it is at the bottom of the list. It's not a Mooney, but it's far faster than other floatplanes with the same engine.
  10. Jun 3, 2019 #990
    Eugene
    Eugene
    Eugene
    May 26, 2017
    596
    109
    So, I need to convert my Skyboy from 1:1 to 3:1 shape.
    I think Rutan in his video was talking about 3.7:1 ratio. But I am not sure.
  11. Jun 3, 2019 #991
    Eugene
    Eugene
    Eugene
    May 26, 2017
    596
    109
    Sorry, my mistake! We were compering to regular non float planes. I will do better next time.
  12. Jun 3, 2019 #992
    11,405
    2,092
    2.5:1 might work. Need to look up the data.
  13. Jun 3, 2019 #993
    Doggzilla
    Doggzilla
    Doggzilla
    Jun 2, 2013
    1,597
    326
    Everywhere USA
    No need to apologize, it's understandable.
  14. Jun 4, 2019 #994
    AdvenJack
    AdvenJack
    AdvenJack
    May 11, 2019
    35
    21
    Florida - Between St. Pete & Weeki Wachee
    To: POORMANSAIRFORCE,
    That ain't a bad rename, but,
    I'll submit for consideration...
    :D SKYCZAR :D
    And if Eugene gets a boat...
    SEACZAR
    Eugene likes this.
  15. Jun 4, 2019 #995
    3,498
    999
    Somehow Eugene strikes me as a worker not a king
    AdvenJack likes this.
  16. Jun 4, 2019 #996
    Doggzilla
    Doggzilla
    Doggzilla
    Jun 2, 2013
    1,597
    326
    Everywhere USA
    Well, he works in HVAC. Might as well call it the "Skyjourneyman".
  17. Jun 4, 2019 #997
    AdvenJack
    AdvenJack
    AdvenJack
    May 11, 2019
    35
    21
    Hi PROPPASTIE :),
    Regarding your observation in Post 995, I respectfully submit that I was offering up,
    (in jest) a name for an airplane owned by an obviously Russian gentleman. Not at all
    was I suggesting a nickname for forum member EUGENE. :D No doubt that he is able
    to get his work done, whether in his vocation or his recreation!
    proppastie likes this.
  18. Jun 5, 2019 #998
    3,498
    999
    Russian Airplane needs name of "Beautiful Russian Woman"
  19. Jun 5, 2019 #999
    plncraze
    plncraze
    plncraze
    May 12, 2006
    1,437
    284
    Valentina Tereshkova!
  20. Jun 5, 2019 #1000
    plncraze
    plncraze
    plncraze
    May 12, 2006
    1,437
    284
    Or Laika
