Cutting 1/4" sticks, chop saw
Insect
Nov 5, 2019
26
Hi,
What ideas are floating around which are more comfortable/safer to cut numerous short 1/4" rib sticks than a miter chop saw?
11,428
Harbor Freight sells a tiny little "miniature toy" shop saw for under $50 that is IDEAL for this. You might have to make some improvements to the miter guide, or 3D print some new gadget to make exact miter cuts with it, but the size and desktop space etc. is perfect for this use. The blade is thin enough that you won't waste a lot of splintered wood from traditional wood cutting blades. I believe this is the most cost-effective and time-effective solution by far.
mcrae0104
Oct 27, 2009
4,292
CO
I’d use a proper crosscut sled with a stop block on a decent table saw.
Repeatable, safe, quick.
Or by hand with a miter box as mentioned; whatever makes you happy.
11,428
The X-Acto extruded aluminum miter box (of which I have a few) is all well and good, but it can only do 90 and 45 degree cuts. Let me know what airplane that has ribs designed with only 90 and 45 degree miters on the rib sticks :)
I'll bet dollars to donuts that the little HF mini-cheapie will make rib pieces faster and easier than hand cutting, where a good vertical cut axis is needed.
11,521
Been using my 10" dia sanding disk since building the KR-2 back in the 70's. Cut it close with the miter saw and then get the perfect fit with the sanding disk.
17,984
The plus of manual saws is when it hurts, you didn’t cut all the way through your finger. Power saw, you won’t know until you look. As good as you want the joint, it’s the gussets that are the strength. One degree off won’t matter. I forget the certified plane that none of the cap even touches other capstrip. So many of my model planes prove that every time I land that it’s tough.
Power gets more tear out to deal with. Manual, you can slow down, flip, hold in your hand, or just snap it. That’s also why you can eye it.
Everything CNC, bla bla bla. The reason you build with sticks is it can tolerate lots of not perfect. Every time I think I got it perfect, someone else proves me wrong. Don’t get me wrong, do your best. Capstrip tolerates lots of different bests. That is why its great for homebuilt airplane construction. If you have ever glued two popsicle sticks together, you are in.
Martti Mattila
Feb 24, 2021
113
If you need a multiple amount of similar pieces like you do when making set of ribs you can cut and trim the edges while it is still 1/4 inc thick wide blank and cut it lenght wise afterwards. But there you need a thin blade table top circle saw.
Scottiniowa
Nov 29, 2021
45
Clarksville, Iowa
Have cut 1000's with a band saw, (most will have a fine tooth blade already) And generally the table is up chest high so your not bending over to observe. Very precise cuts can be made. With a touch of ingenuity, you can make kerf cuts for joining. (angled fence to blade)
but if your always making 90 degree cuts, a steel band saw also works if you have a fine tooth blade. Very simple.
Insect
Nov 5, 2019
26
I appreciate the insight folks. The Harbor Freight chop saw probably fits this task quite well despite being certainly a low quality tool.
The trained termites are probably more durable and higher quality than the HF saw; but leave more collateral damage.
David L. Downey
Curmudgeon under refinement
Aug 7, 2019
318
Harleysville, PA
as a retired career materials engineering adhesives and composites guy, a word of warning is due here. common practice in woodworking is to wax or use silicone on the tools and vblades. This will absolutely compromise the strength of the joints. Avoid even minute traces of transfer of those materials to any surface that you mean to bond.
collector
Aug 10, 2016
76
Crystal River Fl
With all due respect, I think you guys are making this as time consuming and difficult as possible. I've built hundreds of stick-built ribs with only a pencil and a small Delta band saw. I don't pre-measure or make bundles of sticks cut to length. I use a long stick, mark the angle with the pencil and cut, starting with the uprights. It should take a whole 90 seconds to have every stick in place.
As far as whether to cut angles or not, the original Aeronca 65CA (and I'm pretty sure Stearman) ribs were all cut at a 90 degree angle.
This is all JUST my 2 cents...... nothing more!
