Curtiss Robin redux?
Autodidact
Oct 21, 2009
4,513
Oklahoma
How about a homebuilt experimental Curtiss Robin? With a 300 hp v8 and airboat gearbox you would have an aircraft with the same power loading as a 450 hp DHC Beaver (about 11.6 lb/hp with a 2,000 lb useful load) and a wing loading of about 15.5 lb/ft^2 compared to the Beaver's 20.4 lb/ft^2. Since it would be a practical aircraft, it could be simplified or refined somewhat instead of trying to be a replica of a nice vintage machine; for example, maybe you could add flaps to the wing, give it a larger door for loading bulky objects, or change the wing structure to aluminum or partially aluminum as on Piper Super Cubs. I think it would make a pretty nice and practical bush plane, but not a money earner unfortunately. Build one, move to Alaska, and you'd never have to hike 4 miles to ride the railroad into Anchorage!
FritzW
Jan 30, 2011
3,896
Las Cruces, NM
The Robin has always been on my favorites list. I like practical airplanes so I think it's pretty, especially the cockpit.
I was thinking smaller though. I think the popular "tube and gusset" WW-1 replica fleet could be expanded to include golden age airplanes like the Robin. ...something about the size of a VP-1, VW powered, tube and gusset, 1+1 seating with lots of room for camping gear.
15,842
I can get ahold of a rib jig. A friend restored one. Actually the oldest one. Big airplane. His is OX5 powered.
WBNH
Oct 5, 2006
330
Portsmouth, NH
I was going to say the same thing as Fritz...
...Robert Baslee of Airdrome Aeroplanes did a neat Spirit of St. Louis. It would be mostly cosmetic changes to take that design, use an inline engine like the Aeromomentum Suzuki, and make a cub-sized tandem version of the Robin.
8,695
The old Alco Sportplane from the "Flying and Glider Manual" reprints has a baby Curtiss Robin air about it, that might be a good place to start.
Autodidact
Oct 21, 2009
4,513
Oklahoma
There seem to be quite a few of these things still around, which is kind of amazing; I wonder if you could resurrect the type certificate? Would an o540 be the right engine?
Re the Alco (ALCOR?), make a pop riveted fuselage or do it in wood like the original, and the rest could be Legal Eagle or Stewart headwind or some other similar.
PTAirco
Sep 20, 2003
3,661
Corona CA
I looked at that airplane with the same ideas. Automotive V8 and airboat gearbox. Would make an awesome traveling airplane as far as vintage-type aircraft go. Not fast, no, but you can haul lots of stuff in comfort and style.
Loads of room in there for a V8 conversion:
