Pops, you cut an Oval window Bug in half!?
Say it isnt so!
Say it isnt so!
But per 14 CFR Part 43.1(b)(1), Part 43 does not apply to Experimental aircraft. So the requirements of 43.11 don't apply.
Actually, the language in the current 8130.2J says:But it really does as every E/AB will have a the limitation requiring an inspection conforming to 43 Appendix D...
If a CI is not performed "in accordance..." or "per the scope and detail of..." then theoretically, someone could be cited (in what way?) for not following the prescription of the aircraft's OL's, but given the extremely vague nature of Appendix D to Part 43, which basically says:Can you have the FAA take action against you under FAR pt 43? No. But they can cite your limitation if you do not.
The FAA calls that 'incorporated by reference.' Only the part referenced applies. Alternatively, they could cut and paste Appendix D of Part 43 into the OL's minus legal codification and it would just be a set of instructions. Voila!But it really does as every E/AB will have a the limitation requiring an inspection conforming to 43 Appendix D.
