MadRocketScientist
More progress today.
First up I purchased a brand new towball for pressing these ball joints. Can't go to wrong for $21NZD. I tested it out by making another pressed flange, the hole in the middle giving an idea of how much the mild steel stretches.
Stretches a long way without cracking. The outside sometimes wrinkles where the steel is getting pulled into the hole from the outside.
I marked around the outline with a sharpie and roughed the shape out with some tin snips.
Then cleaned up the perimeter with a flapper disk on the angle grinder. The flange was formed the same way as the earlier post, with a panel beating hammer...
Having completed the flange I then took to the lathe and turned up a couple of the 'ball' parts. The ball is really a ring with a spherical outside shape.
If you look closely there is a recessed step to fit over the exit of the header pipes. I think these may only need to tilt a couple of degrees each way, I will video the joint with the engine running to check how much movement is really needed.
The ball fits quite well on the headers.
I taped the flange to the tuned pipe to do a trial fit of the coupler...
