Could floats be this simple in an UL ?
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by Speedboat100, Aug 9, 2019.
  1. Aug 12, 2019 #21
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    835
    75
    Europe
    Yes and on the shallow shores on the lakes there are a lot of rocks etc.
  2. Aug 12, 2019 #22
    jedi
    jedi
    jedi
    Aug 8, 2009
    1,907
    452
    sarcasm? ;);):confused:
  3. Aug 12, 2019 #23
    10,214
    6,947
  4. Aug 12, 2019 #24
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    835
    75
    Europe
    Do you mean the katamaran type with tunnel hull ?
  5. Aug 12, 2019 #25
    10,214
    6,947
    Sorry. It was a tongue-in-cheek reference to a former (now banned) member here whose solution to everything was a tunnel hull.
  6. Aug 12, 2019 #26
    Himat
    Himat
    Himat
    May 5, 2011
    2,858
    666
    Norway
    Vulnerability to floating debris is one reason that hydrofoils are not much used. Either on floatplanes or fast watercraft. There are some other reasons too. The hydrodynamic lift from a hydrofoil changes when going to fully submerged to be planning on the surface. Then there are practical issues like beaching and docking. Less the vulnerability to floating debris, it is possible to work around this. The Lisa is an example of a plane with working hydrofoils. As for beaching, it has retractable gear, extending further than the hydrofoils.
  7. Aug 13, 2019 #27
    pwood66889
    pwood66889
    pwood66889
    Feb 10, 2007
    1,513
    170
    Sopchoppy, Florida, USA
    `Greed again. Seven inches is not that much freeboard. Also appreciated input from Doggzilla, Aesquire, and BJC.
  8. Aug 17, 2019 #28
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    835
    75
    Europe
    This has some boxy features and looks like simple to make too. What is it actually ?
    Battler Britton likes this.
  9. Aug 17, 2019 #29
    Howe
    Howe
    Howe
    Apr 21, 2013
    28
    12
    Brisbane/ Australia
    So her's my Rotax 503 powered U/L. Can change from wheels to floats in about 15 mins,almost the same both modes but a whole lot more fun over water.
    nzdavmo and thump like this.
  10. Aug 17, 2019 #30
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    835
    75
    Europe
    Whoaa..is this your own design ?
  11. Aug 18, 2019 #31
    Howe
    Howe
    Howe
    Apr 21, 2013
    28
    12
    Brisbane/ Australia
    Well have been flying on wheels for about 10 years then the floats came up for sale and I decided to adapt them. Just re calculated the so the cog remained exactly the same and it flew perfectly as with wheels.
  12. Aug 18, 2019 #32
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    835
    75
    Europe
    What type of ultra is it ?
  13. Aug 20, 2019 #33
    Howe
    Howe
    Howe
    Apr 21, 2013
    28
    12
    Brisbane/ Australia
    It just a basic rag and tube meets 95.10 Recreational Aviation Australia MTOW 300 KG.
    Iam only 65 kg so that helps. Floats are hollow fibreglass weigh about 32 kg all up.
    They have a Vee bottom not flat which provides better handling and directional stability.
  14. Aug 20, 2019 #34
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    835
    75
    Europe
    Yes you need more rudder area to compensate boxy floats..that weigh about 6 kilos each when ready. It is easy to design the rudder system now..when one knows what kinda floats one is having. Also the water operations in general demand more rudder.
  15. Aug 21, 2019 #35
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    835
    75
    Europe
    I drilled some lightening holes in it and got it down to 34 grams..that would indicate around 7 kg per float. I have to make'em ( floats ) smaller apparently to reach 5 kg per float.
    Yes I counted I can make them to 18 cm wide..narrowing them 7 cm each..getting them down to 5 kg a piece.
    https://en.wikipedia.org/wiki/Buoyancy
  16. Aug 21, 2019 #36
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    835
    75
    Europe
  17. Aug 21, 2019 #37
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    835
    75
    Europe
  18. Aug 21, 2019 #38
    13,165
    5,077
    Or an air-blown hover skirt.
  19. Aug 22, 2019 #39
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    835
    75
    Europe
    I made the 1/3 scale float for my special hyperlite electric water and ground operated craft.
    To meet my criteria it ought to weigh 185 grams. Foam + sides were 140 grams. I am pretty close on the target.
    It is being cured after clueing. I had to do some mods on it...the step is a bit more forward...and placing then again slightly more aft of the previous BLUE FOAM.
  20. Aug 23, 2019 #40
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    835
    75
    Europe
    Here is the raw version of the 1/3 scale float. It is estimating around 60-70% less weight than the regular Part 103 float.
