rv6ejguy
You can see one of the other projects Jeff Kerlo is working on here. Pretty neat stuff.
Cute little plane - be interesting to see what the market is.You can see one of the other projects Jeff Kerlo is working on here. Pretty neat stuff.
I noticed the same thing. I figured he did 1100/350 = 3 G's when he should have done 350/1100 = .3 G's...Did I miss something?
Yeah, that comment made me think too. My RV weighs about 1100 empty and makes about 700 pounds of static thrust. Not even close to 3G acceleration if I boot it with full throttle.Cute little plane - be interesting to see what the market is.
I was somewhat perturbed, though, that John stated that the twin jet version will accelerate at 3G (which he mentions a few times) with 700 lb. of thrust and an 1100 lb. MGW. Even if EACH of the engines produces 700 lb. of thrust (I don't think that's the case, but lets be generous), then with 1400 lb. of thrust and 1100 lb. of weight, I get 1.27 G acceleration, or (with 700 lb of thrust - more likely) 0.64 G. Either one of these is going to be exciting - hell, even the single jet version, with 350 lb. of thrust, would be exciting - but it's not Spaceship 1's 3 G's. This is a relatively trivial calculation...
Mistakes like make me wonder what other errors there may be.Cute little plane - be interesting to see what the market is.
Yes, the BS in Modern Marketing of Kitplanes.Did I miss something?
Yes, but we have to hope that only part of the team are halfwits. I for one would never let a marketeer publish something that I hadn't checked. It's quality control on a highly visible aspect.Ads and articles are written by people who write ads and articles, not engineers.
Jet engines have an interesting characteristic - if the inlets will allow enough airflow when stationary, thrust is essentially flat from stationary to pretty good cruise speeds. The things that drive thrust less than the max are - small inlets, and compressibility effects, which interact with each other:Would that be a static thrust #? Don't turbines have a lower static thrust then when they get up on it and really start moving through air?
Afterburner?
Point straight towards the ground (1G), go full throttle(+1.27G), round up, and presto, 3G acceleration!Cute little plane - be interesting to see what the market is.
What do you expect when they don't even do a grammar/spelling check. I think 70% of the people creating their own website flunked 7th grade English class. (or maybe they are still in the 7th grade?Yes, but we have to hope that only part of the team are halfwits. I for one would never let a marketeer publish something that I hadn't checked. It's quality control on a highly visible aspect.
Look at the Raptor. Impossible performance claims. The bullpoop has doomed it even if it does fly passably. Even if it has a 1500 mile range and manages 200kts, which is possible, it is a failure.
Unlimited races are for piston powered aircraft only. The Jet Class speeds are far above what this plane could do on the course and you wouldn't want to be out there in the jet wash with such a lightweight design anyway.The Voodoo can incorporate up to 2 small turbines. PBS is offering a new 1500N version which states the current theoretical maximum in terms of what you can fit to the plane. He said it would not be for everyone, meaning you have 120k euros for the engines alone.
With 3000N for 1000lbs it seems to me he mistook the newton for lbs, as their other supplier is stating the thrust in lbs instead. Another thing is, that the twin jet will be limited to around 15 minutes of autonomy. So main use case seems to be Reno unlimited race.
You forget about the 65 year old ex airline pilot who cannot afford a F-35Unlimited races are for piston powered aircraft only. The Jet Class speeds are far above what this plane could do on the course and you wouldn't want to be out there in the jet wash with such a lightweight design anyway.
Some of us half-wits can write sales BS that just smells so good that the boss is seduced and he lets it go out as isYes, but we have to hope that only part of the team are halfwits. I for one would never let a marketeer publish something that I hadn't checked.
