Contraelectric
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by Jstorrshall, Oct 13, 2018.
  1. Oct 13, 2018 #1
    Jstorrshall
    Jstorrshall
    Jstorrshall
    Sep 3, 2013
    20
    3
    Melfa, VA USA
    Norman likes this.
  2. Oct 13, 2018 #2
    Cy V
    Cy V
    Cy V
    Jul 1, 2008
    403
    113
    Virginia
    No, I haven't seen that before. Very interesting.
  3. Oct 14, 2018 #3
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    2,819
    476
    capital district NY
    nope, interesting.
  4. Oct 14, 2018 #4
    lr27
    lr27
    lr27
    Nov 3, 2007
    3,216
    462
    They've had this in the model airplane world for a while.
    At this point, props and motors are the easy part. Batteries are still the hard part.
  5. Oct 14, 2018 #5
    Sockmonkey
    Sockmonkey
    Sockmonkey
    Apr 24, 2014
    1,537
    393
    Flint, Mi, USA
    It is clever to make it compatible with being retrofitted on an existing plane.
  6. Oct 18, 2018 #6
    Andy_RR
    Andy_RR
    Andy_RR
    Sep 29, 2009
    140
    64
    Melbourne, Australia
    ...except that going electric pretty much demands that you use every aero trick in the book to minimize drag to achieve reasonable range. Retrofitting existing airframes seems to me to be the realm of experimentation only.
  7. Oct 18, 2018 #7
    lr27
    lr27
    lr27
    Nov 3, 2007
    3,216
    462
    Unless you start with an airframe that's already made to be really efficient, like a sailplane. And batteries continue to improve.
  8. Oct 18, 2018 #8
    5,591
    1,422
    But sailplanes don't have engines to replace...
  9. Oct 18, 2018 #9
    lr27
    lr27
    lr27
    Nov 3, 2007
    3,216
    462
    Ok, then use a lowly motorglider.
  10. Oct 18, 2018 #10
    Sockmonkey
    Sockmonkey
    Sockmonkey
    Apr 24, 2014
    1,537
    393
    Flint, Mi, USA
    True, but creating a new production line aircraft is financially risky, so making it retrofittable to existing ones is a way to get the tech out there.
  11. Oct 19, 2018 #11
    leifarm
    leifarm
    leifarm
    Dec 10, 2012
    44
    11
    Norway
    Retrofitting FES (folding propeller in the nose) is possible on pure sailplanes as long as the weight of non lifting parts is not exceeded. Many sailplanes have retractable engines for self launch or to avoid outlandings.
  12. Oct 19, 2018 #12
    8,672
    5,570
    I heard that a bright, young, aero engineer in the Netherlands is developing an electric launch package that will be retrofittable to several popular sailplanes. Reportedly, it places batteries in some of the wing space originally used for water ballast and places an electric motor in the nose, which will be modified to slide forward to allow a folded propeller to extend. To save weight, no controller is used; in-cockpit switching will allow either 50 percent power or 100 percent.
    What I haven’t yet discovered is the projected first flight date, but I eagerly await the event.
  13. Oct 19, 2018 #13
    5,591
    1,422
    A controller will allow use of a brushless motor. The added efficiency of a brushless motor means less batteries needed. A no controller solution won't save weight...
    BJC likes this.
  14. Oct 19, 2018 #14
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,526
    413
    krakow,poland
    -we have some positive results with conterrotating propellers=
    =1 kW electric with 15 kG thrust, 1.3 m propellers...
    =circa 70 HP (5000 RPM) G13 , 215 kG thrust force, 1.7 m LUGAPROPs...
    (prototype gear,circa 2 kg,0.5 l volume)=low noise,focused,streamline powerfull
    afterpropeller flow=no possibility stay on futh 5 m rear!
    PS=aspatially interesting is REACTIONLESS ,
    GEARless conterrotating system ...(electro)
    BJC likes this.
  15. Oct 19, 2018 #15
    Sockmonkey
    Sockmonkey
    Sockmonkey
    Apr 24, 2014
    1,537
    393
    Flint, Mi, USA
    Considering the mass of batteries, it makes me wonder about the viability of sticking them on sliding racks for weight-shift control of pitch and roll.
  16. Jun 7, 2019 #16
    Nicholette
    Nicholette
    Nicholette
    Oct 26, 2014
    3
    0
    UK
    So I may yet be able to make a 2/3 Gannet in the Garage?
