Kind of looks like Leonard Millholland (Legal Eagle) and Steve Wood (Sky Pup) got to brainstorming together.
What is the total/flight configuration wing-span?I really like the way yours looks. Put a pilot in it so we can see how it looks loaded. This pilot is 6' tall. I was kind of surprised that the model ended up with so much headroom (maybe I missed something). Usually my sketches are pretty tight.
The thing I drew would fit in a 16' space with the wings off. If it were set up for folding it would be too long.
The seat is pretty reclined on this concept. Since it's just a drawing I haven't set up incidence and gear height for optimal takeoff/landing. It looks "about right." But I haven't done the math.
If it looks a little short in the nose it's because I assume a heavier auto conversion. A lighter motor could be used. Just have to rework the nose/motor mount. Again all based on TLAR.
Rob
Isn't this just the Fritz design? Great looking pilot, though...I really like the way yours looks. Put a pilot in it so we can see how it looks loaded. This pilot is 6' tall. I was kind of surprised that the model ended up with so much headroom (maybe I missed something). Usually my sketches are pretty tight.
Rob
I always loved Low Aspect Ratio designs. This was my thought about a easy storable light airplane. Rudder is easy to dismount. The rear part hinges up and folds over front and the total gets pushed sideways in a garagebox.
Airplane has a transparent front like some early Horten flying wings had.
View attachment 120134View attachment 120135View attachment 120136
The Fleabike is about to enter a period of quite rapid construction. For the past few months it has been a case of CAD and issues with the CNC. But the CNC should be back in action in a few days, and the CAD is (mostly) now complete. I hope to complete the rear wing and try out the folding mechanism. That is going to be fun.Well yeah, sort of. Except it's plastic and has a much higher aspect ratio wing. And to be honest I wasn't thinking about Fritz's design when I skeched it. I was more interested in Floyd's Cub design. I like Fritz's design. looks cool. Just dont like all the fiddly wood bits.
What's going on with the Fleabike? I've been following your build and like that you're a dancer too. Wish I had music. Any closerMrch - so we;re training every single day for a couple of hours.
Yes.Probably a stupid idea...wanted to cut the leading edge root back and blend into intakes for a TJ100 powered wing...
Couple of your doodles look a lot like mine but much better! I love a true flying wing but as an F-16 guy I’d love to have that glider-like cockpit and visibility that a forward sweep can provide. I really don’t want a tail though…turns revolutionary into ordinary. Just dreaming.I like the idea of swept forward wings as much as swept back, although I find forward works out better from a pilot/structure layout point of view.
I'm also into metal;
Although I've looked into glass/foam sandwich composites;
I mean, most of these were pure dreaming, but ideas have to start somewhere.
So I was both a sailplane and hang glider pilot, and always wanted to mix the best of both;
One man portability.
Stand alone operation.
Reasonable performance.
Too old to go jumping off cliffs now, so I'll stick to ultralights, and maybe UL gliders.
Turns instability into stability, afterall, it IS a Vertical Stabilizer...I really don’t want a tail though…turns revolutionary into ordinary. Just dreaming.
If there’s no instability in yaw, no need for a vertical stabilizer. Hence the importance of proverse yaw in a flying wing with a BSLD integral to its design.Turns instability into stability, afterall, it IS a Vertical Stabilizer...
Thank you.Adverse Yaw acts counter to the roll in a turn. The nose tends to swing out, away from the roll. As far as I know, there is no fixed-wing aircraft that doesn't experience adverse yaw.
Thank you. I worked for over a month putting all of it into the right scale to look right and BE a flying crotch-rocket.By the way…your “Crotch ‘Stang” is so flippin’ cool!
