Composite Tube making
Discussion in 'Composites' started by berridos, Mar 10, 2011.
  1. Mar 10, 2011 #1
    berridos
    berridos
    berridos
    Oct 10, 2009
    804
    47
    madrid
    Nike-Asp
    They fill nitrogen into the tube
    Cannot find the original thread
  2. Mar 10, 2011 #2
    Norman
    Norman
    Norman
    Nov 29, 2003
    2,879
    918
    Grand Junction, Colorado
    Here's a rather long one. It drifts a bit but gets back on topic and several methods are described including rocket body tubes. The google search button often works better than the built in search function
  3. Mar 10, 2011 #3
    autoreply
    autoreply
    autoreply
    Moderator
    Jul 8, 2009
    10,732
    2,539
    Rotterdam, Netherlands
    A lathe-cut foam core:
    YouTube - rough turning foam
    Seems like another interesting solution. Styrofoam can be eaten away after the lay-up has cured and this makes tapered tubes possible too.
  4. Mar 11, 2011 #4
    JamesAero
    JamesAero
    JamesAero
    May 10, 2010
    46
    0
    Salem, OR
  5. Mar 13, 2011 #5
    JMillar
    JMillar
    JMillar
    Jan 18, 2007
    233
    0
    Antigonish, NS, Canada
    I didn't look at all the links, so this might have been covered. In a book about composites I have, the author talks about how the spar for, I think, the Gossamer Albatross was made. They took an aluminum tube and layed up uni pre-preg on that, then wrapped it in heatshrink plastic. Then hot oil was pumped through the tube, both curing the prepreg and shrinking the wrap, which acted like vacuum bagging. After it was done, the aluminum tube was dissolved out with acid. Sounds like a pretty impressively innovative solution.
  6. Mar 14, 2011 #6
    berridos
    berridos
    berridos
    Oct 10, 2009
    804
    47
    madrid
    Dissolved with acid? That sounds scary.
    What acid dissolves aluminium and preserves your lungs?
    With eating up a lower and upper channel of the alu tube the rest could be pulled out easily.
    I like the idea if it wouldnt be as dangerous as it sounds.
  7. Mar 14, 2011 #7
    Norman
    Norman
    Norman
    Nov 29, 2003
    2,879
    918
    As I recall MaCready used chlorine from a swimming pool supply store
  8. Mar 15, 2011 #8
    Oct 19, 2003
    5,711
    2,951
    Read the other thread. All of this stuff was already talked about, and in detail.
    Dr. McCready used swimming pool acid. Yes it had to be nasty compared to the stuff I found to be inadequate...
