Laromin
A gear of the same shape and size of the aluminum one would weigh about 46 percent less if made out of carbon,mostly tow.
I saw a picture of a carbon zivko gear somewhere.The Extra 260 had a glass tow gear,but it was quite a bit thicker than an aluminum one.
All the Extra 300 gears are glass composite.
In any case it could be done,the most important thing being that small bend radii are to be avoided.(Sort of copy the Extra 300).
One could also start with an aluminum gear that is maybe 4mm thicker and mill away material to end up with an I-beam with vertical support pillars.
Would need to be done on a CNC and cost a lot more,but again you could save half the weight.In general a lot of metal hardware can be lightened/optimized by machining .
