craftsven
This is my 11th "One of a Kind" Experimental
I started designing and building in the fall of 1999 and test flew her in the summer of 2000
The fuselage is Rag & Tubing, the wings are all wood.
Gross weight 2400 lbs
Empty weight 1206 lbs
Wingspan 38 ft
Airfoil 23012 NACA
Seats 2 in tandem
Floats are "Fiberfloats Mod. 2400" Kevlar with Inverted hull, Hydraulic operated water rudders, two pumps located in the main float compartments. Rudders are controlled by a 4 way switch in the cockpit, (Left, Right, Up and Down)
Powered by a Walter M337, 210 Hp, Inline 6 cylinders inverted, Supercharged, she was the smoothest Piston engine I've flown behind. Highly recommended. Biggest bang for your buck.
But don't buy from "Moravia Ltd. Thunder Bay Canada.
Propeller is an AVIA V 500 Constant Speed
Cruising speed on floats 150 mph
Note: Number 12 can be seen at "Tell us what you're building"
