Combining Functions of Harmonic Dampner and flywheel
Discussion in 'Chevy' started by ekimneirbo, Aug 30, 2013.
  1. Aug 30, 2013 #1
    While thinking of ways to lighten an auto conversion (LS Chevy in this instance), I'd like some input on the dynamics of using a harmonic dampener to also compensate for some of the flywheel mass and still get the benefits of damping. My plan is to use a short splined shaft inserted in an adapter that is bolted to the rear of the crankshaft. The shaft will drive the propellor and be supported by a housing. The LS engine will have a stock harmonic dampener affixed to the front of the crankshaft as per factory installation. On the rear of the crank an ATI Rattler or Fluidamper would be attached to the flywheel to deal with any harmonics from the propellor. The flywheel would be lightened by appx the weight of the dampener.
    Most sources I have seen recommend using a somewhat heavy flywheel to help the engine run smoothly. I also don't want to add unnessesary mass to the drive. The aftermarket dampeners are designed to deal with harmonics thru all rpm ranges while the factory units usually concentrate on one rpm range. Anyone see any conflict problems surfacing if two dampeners are used?
  2. Aug 30, 2013 #2
    rv6ejguy
    rv6ejguy
    rv6ejguy
    Jun 26, 2012
    3,749
    2,812
    Calgary, Alberta, Canada
    V8 engines don't really need much flywheel inertia to run smoothly. I've idled an LS6 down to 500 rpm with just the basic ring gear- no clutch stuff and it was still smooth. If you use a wooden or composite prop, I don't think you'd have any concern with harmonics from the prop. With the lack of torque reversals on a V8, I wouldn't expect any TV problems with a stiff shaft and front bearing setup. The V8 should be way more benign than a 4 cylinder in this regard and you should be able to keep the rotating components light.
  3. Aug 30, 2013 #3
    Toobuilder
    Toobuilder
    Toobuilder
    Jan 20, 2010
    4,537
    3,383
    Mojave, Ca
    Two thoughts:
    What are you using for a prop?
    ...and IF you need more flywheel, (big if), you can always attach a steel ring to an auto trans flexplate. Won't add much dead weight, but plenty of inertia.
  4. Aug 30, 2013 #4
    Toobuilder
    Toobuilder
    Toobuilder
    Jan 20, 2010
    4,537
    3,383
    Mojave, Ca
    one more thought
    It would be slick to build a large diameter pendulum dampener that replaced the starter ring gear entirely and also incorporated a splined output. Idealy, you could open the unit up and replace/service/tune the guts for a variety of engine/propeller combinations. I guess the reality is that you would need to do a TV survey on every combination and have the results cataloged somewhere...
  5. Sep 1, 2013 #5
    I do plan on using a carbon or wood propellor and agree that there is much less chance of TV with them. I will obviously have to run a flywheel of some type and feel that just a flexplate would be too light. I have several LS1 flywheels, so I turned one down a few lbs and took it to the local clutch rebuilder and had them resurface both sides to insure it was flat. I got rid of about a third of the weight. I was thinking that with a little mechanical creativity that I might be able to
    use a Fluidamper that I have from an old car project, and attach it to the flywheel (after further lightening) and gain some benefit....kind of a win/win situation. I might be able to just attach it to a flexplate and end up with the same appx weight as a flywheel. That would be pretty simple to do. As you say, its probably not needed. I plan to use a dynovibe to check whatever I do, so maybe I'll try both and see what the result is. Its a ways off right now as I'm embedded in some other projects right now.
  6. Sep 1, 2013 #6
    RJW
    RJW
    RJW
    Feb 9, 2011
    708
    207
    Wisconsin and Kansas
    Using lighter and stiffer stuff will simply shift any resonance to a higher frequency (as we have discussed here many times). I don’t recall details but an analysis worked out a couple years ago using a wood prop and a reasonable guess for the stiffness of a SBC crank put first order resonance in the operating range. The point of the exercise was to see if lightest stiffest stuff would put resonance above the operating range of the motor. Unfortunately it didn’t. If one is guessing and testing, it is probably best to go heavy with the flywheel and prop, and use a soft system to put the first order below the operating range. Second order will then probably end up somewhere in the operating range so you will have to avoid that RPM or provide a damper for it. Higher orders have much less amplitude and "generally" do not cause problems.
    Let us know what your tests show.
    Rob
  7. Sep 1, 2013 #7
    Midniteoyl
    Midniteoyl
    Midniteoyl
    Sep 4, 2003
    2,406
    500
    Indiana
    I was thinking of using a TCI Rattler.. been a long time since I thought about it/looked it up, but I believe the TCI would be better suited.
  8. Sep 1, 2013 #8
    rv6ejguy
    rv6ejguy
    rv6ejguy
    Jun 26, 2012
    3,749
    2,812
    I think you'll find F1 with a wood prop and super stiff shaft down in the 300-400 rpm range which is transitional, not operational. MMOI would not be markedly different than with the standard flexplate and torque converter in place.
  9. Sep 2, 2013 #9
    RJW
    RJW
    RJW
    Feb 9, 2011
    708
    207
    I’ll dig out my notes and run though the process again. I need to sharpen up anyway. So the implication is that F1 on a regular SBC or similar V8 fitted with stock flexplate/torque converter or flywheel/pressure plate occurs at 300-400RPM? It seems like the crank would be pretty rubbery if that were true. I thought the stock dampers were there to handle F1? Aren’t the stock dampers tuned to about 3200RPM? It’s very possible that I am remembering all of this wrong. Is the damper there to handle higher orders? I really don’t know. Anyway, if the implication is true, then use the lightest flywheel, pretty much any prop you want, find out where the full sine wave occurs, damp and avoid.
    Rob
  10. Sep 2, 2013 #10
    rv6ejguy
    rv6ejguy
    rv6ejguy
    Jun 26, 2012
    3,749
    2,812
    I couldn't say what ranges the factory engineers were aiming to tame on the automotive application and how well it does the job over the full rpm range (good enough that the crank has basically infinite life in stock form).
    I'm going to try to plug some MMOI estimates for this engine into my spread sheets assuming a very stiff shaft and simple 2 element model and a 15 lb, 80 inch prop. A torque converter filled with oil is not exactly light.
    The safe bet might be to leave room and use the same bolt patterns on the extension shaft setup to be able to insert a Lovejoy type damper, instrument the shaft with WBs in solid form, then if you have bad TV shown by the instrumentation, you'd be able to pick a suitable damper from the catalog. We've got some math models and actual test info for the Subaru engines and the M300 gearboxes now and they agree quite closely. This was preceded by a actual MMOI measurements and stiffness measurements of all the components. Many hours of calcs but this was a far more complex model.
  11. Sep 2, 2013 #11
    rv6ejguy
    rv6ejguy
    rv6ejguy
    Jun 26, 2012
    3,749
    2,812
    Looks like I was pretty wrong with my post above. It pays to work the numbers.
    I spent a couple hours estimating MMOI of the crankshaft, rods, OEM damper, flexplate and a 15 lb., 80 inch wooden prop. Plugged these numbers into my Holzer spreadsheet and varied the coupler stiffness. If my estimates and calcs are correct (a big IF), it looks like if you bolted the prop right to the flexplate with an uber stiff, metallic adapter plate (3750 lb/ft/deg), resonance with firing frequency on a V8 would occur at 2948rpm.
    With a super soft coupling (100 lb/ft/deg) resonance at 150 rpm.
    With a medium hard coupling (800 lb/ft/deg) at 430 rpm.
    Since most starters turn the engine at 200-300 rpm, it might be good to avoid this range, either above or below this and below the idle range of say 600-800 rpm.
    This is more for illustrative/ discussion purposes, showing possibilities rather than solid numbers which would require actual MMOI measurements of the parts via bifilar suspension tests.
    We have a number of 4 and 6 cylinder DD auto engines with many flight hours turning lightweight props with "solid" metallic couplers. These may be more successful than a V8 DD because of the firing frequency differences. Generally, resonance with firing frequency would be well above the operating range of a DD prop on a four and most sixes as well but maybe not on the eight.
  12. Sep 2, 2013 #12
  13. Sep 3, 2013 #13
    rv6ejguy
    rv6ejguy
    rv6ejguy
    Jun 26, 2012
    3,749
    2,812
