flyoz
Colomban " Banbi " MC 100 Plans for sale
Registered set of MC100 plans for sale , 2 seat side by side aluminum aircraft
They consist of
36 large sheets of plans
Banbi build manual ( French ) . I also converted the pages to "Word" in preparation for doing a translation so that is in electronic format .
I also set up a list of all part numbers cross referenced with sheet numbers and their English translation ( almost complete but needs final checking ) - Many hours of work already done
Cri Cri build Manual ( French )
Hand file with material sources , some smaller drawings and further collected info
Electronic format ( disc )photos of aircraft and parts collected from the net
Specifications
200Kg / 440 lbs empty
Max weight 450 Kg / 990 Lbs
Motor 80 Hp Rotax
Stall ( flaps ) 49 Kts / 56 Mph @ 450 Kg / 990Lbs
VNE 184 Kts / 211 Mph
Max 165 Kts / 190 Mph
Cruise 156 kts / 180 Mph
10 mins from trailer to flight
Parts available from France
Prop and spinner
Canopy
Wing tips and elevator tips
Engine cowlings
Main spring gear
Wheel spats etc
This is an impressive aircraft if you compare it to say an RV7A ( 160 Hp + the Banbi has 80 Hp)
The max speed is only 10 Kts /12 Mph faster than the Banbi and the stall speed at max weight is about the same 49 Kts / 56 Mph
The RV can take 78 Kg / 178 Lbs more load but if you adjust the difference for fuel burn that benefit is largely lost
The Banbi is rated at 4.4 G's positive and 2.2 G's negative so its very strong too
I paid about 500 Euro ( US 617 Dollars ) and i am open to offers
( about 1.227 US Dollars to the Euro today 28 May 10 )
Mike email [email protected] ( In Australia )
They consist of
Specifications
Motor 80 Hp Rotax
Prop and spinner
Canopy
Engine cowlings
Main spring gear
Wheel spats etc
