CNC Ribs
rtfm
Jan 3, 2008
3,601
Brisbane, Australia
Hi David. If all you want to do is to cnc cut your ribs, then Vigilant1 is right on the money. CNC can quickly become a very engaging hobby in its own right. And if you are working from plans (as you are) then it's a single visit to the Makerspace.
Question 1: who put the rib profiles into CAD for you?
Question 2: what material did you use for the ribs?
1Bad88
Jul 18, 2012
620
Bellville, TX
I really like the Momus CNC. I bought the plans, started the project, moved 3 times, and had to ditch the parts before I could finish but it's a nice rigid machine for low cost if you want to build one. Plans are cheap too.
David H
Jul 30, 2019
14
RTFM, Fritz shared the CNC files with the Volksplane Group and I used 1/4 inch Mahogany AC/Marine plywood from Boulter Plywood in Mass. Not a CNC issue but they also had the Sitka Spruce in 20' lengths.
