Cheap aircraft are simply impossible? :(
Discussion in 'Hangar Flying' started by Inverted Vantage, Nov 15, 2009.
  1. Apr 7, 2019 #1261
    rtfm
    rtfm
    rtfm
    Jan 3, 2008
    3,193
    572
    Brisbane, Australia
    Define cheap. My AeroMax (wings and tail feathers completed) now needs the fuselage kit. $8k (AUD) That's not expensive, except that the entire Ranger can be built for less than half that amount. I looked into building the Airbike - Wings $2500, Airframe $6999 (USD). The Legal Eagle is $3000 - $5000 ($4500 - $6500) - and you need to be able to weld. Even the Affordaplane is about $3000 USD ($4500 AUD) and you need to source 6061-T6 AL tube (which can't be had in Aussie for love or money).
    The Ranger (like the Aeromax) is almost completely CNC cut, and uses plywood. But the Ranger costs about a third of the price.
    For me it's a no-brainer.
  2. Apr 7, 2019 #1262
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    375
    96
    Lt
    But still - is it build from common available materials ? Or you have find them hard way ? I had bought rag wing stork plans - shoul be on cheap side if try to find all wood locally, dry it yourself but plywood is no go on same scenario.
    Or go cnc foam plus fiber glass... Like hero of modern gyrocopter have done in past with home moulded fiberglass rotor.
  3. Apr 7, 2019 #1263
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,389
    3,316
    Wisconsin
    A kit is optional right? You can scratch build a Minimax and the materials can be pine.
    What kind of plywood is the Ranger made from? Maybe I'm missing something so illI go re-read the thread but there's nothing cheap about aircraft plywood.
    Like I said, I'll re-read the thread maybe I missed something.
  4. Apr 7, 2019 #1264
    2,972
    1,671
    I think this thread so far is easy enough to sum up:
    “Whether you think you can or you think you can’t, you’re right.”
    Jean Crous and nerobro like this.
  5. Apr 7, 2019 #1265
    11,915
    3,412
    It’s only cheap because someone is graciously sharing their work. I don’t know if any true materials have been stated as required. If it was a for sale kit, it would be smack in the meat of it. It’s not any cheaper, you are getting a freebie.
  6. Apr 7, 2019 #1266
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    3,326
    586
    capital district NY
    "Cheap" somehow seems the wrong word to describe any aircraft. Perhaps "inexpensive" would be more "PC"? Or "Affordable"?
  7. Apr 7, 2019 #1267
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    375
    96
    Lt
    Just stumble on this info today :
    And
  8. Apr 7, 2019 #1268
    10,027
    6,776
    Let’s hope that he tests it before trying to fly with it.
  9. Apr 7, 2019 #1269
    4,240
    1,973
    It would be interesting to hear the reasoning behind the approach he has taken. A foam-core spar web with CF or FG at 45 deg to the caps would help keep his spar caps in alignment (in three axis) and provide a compression-resistant member between the upper and lower caps. I guess he is counting on that sinusoidal (carbon?) truss web to do that.
  10. Apr 7, 2019 #1270
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    375
    96
    Lt
    Really don't know. I would do in 3d traindulat truss anyway.. Remeber me of on photo from past - rib made from mono filament of fiber-glass, on mold made just from piece of plywood and nails... Just wet fiber with epoxy and build a web.. Cant't find it now, but will try.. Still - 50 kg of fiberglass is cheaper and faster than aircraft grade wood + plywood.
  11. Apr 7, 2019 #1271
    choppergirl
    choppergirl
    choppergirl
    Jan 31, 2015
    1,603
    586
    Choppergirl's Flying Circus ★★☠★★ AIR-WAR.ORG
    Cheap is anything under $1,500.
    Just okay is anything under $2,500, but it *better* be flying. Not pretty, just flying.
    A Choppergirl Special is anything under $199. Don't bid on those, those are for me only.
    But shoot a link to them to me when you find them ;-)
    $10K is my house. No little dinky private putter airplane is worth a house.
  12. Apr 8, 2019 #1272
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    375
    96
    Lt
    Hi ! Prices are for bare field/no workshop ? Or only raw materials..
  13. Apr 8, 2019 #1273
    theecoop
    theecoop
    theecoop
    Feb 8, 2009
    13
    9
    Niles,Mi/USA
    The Aeromax Fuselage kit is $5,000.00 USD which includes hardware machined for you. Landing gear, covering kit.. Most charge extra for all that.
    So I find it very reasonable.
    Like putting a puzzle together being lazer cut, and hardare machined.
    Regards,
    David Cooper
    Director of Operations
    Team Mini-max
  14. Apr 8, 2019 #1274
    11,915
    3,412
    The guy has other videos on his spar and wing thinking. He has to be pretty close to me as he is listening to the same radio stations I do. I’m not getting in it.
  15. Apr 8, 2019 #1275
    theecoop
    theecoop
    theecoop
    Feb 8, 2009
    13
    9
    Niles,Mi/USA
    Team Mini-max has a New Epic Sport kit coming out soon 25,500.00 includes everything except paint. 85
    HP Hummel Engine, full steam standard Instrument too
    Wayne, cluttonfred and blane.c like this.
  16. Apr 8, 2019 #1276
    7,216
    2,059
    Finally, an LSA in the spirit that it was created for!
  17. Apr 10, 2019 #1277
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,389
    3,316
    Wisconsin
  18. Apr 10, 2019 #1278
    12,480
    2,523
    I don't see any engine.
  19. Apr 10, 2019 #1279
    2,972
    1,671
    I wonder if either he has the engine above the wing's trailing edge and the prop horizontal, or more likely he was going to get it towed up to flying speed.
  20. Apr 10, 2019 #1280
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    3,326
    586
    capital district NY
    Ok. (1) The last sentence in the report says "The CAA said that they appreciate the passion and skills of Fayaz and would provide him with the required guidance to achieve more expertise in the field."
    (2) look at those wings and tell me they are going to produce lift.
