Cheap air racing class to promote aviation?
Autodidact
Oct 21, 2009
4,513
Oklahoma
A thought about ignitions: aren't the ignitions on most industrial engines basically just a magnet whirling past a coil? Ie, no alternator per se, but as the magnet speeds past the coil, it creates a current by induction and the speed at which it grows and decreases determines the strength (voltage), in other words it's the same thing as when a set of points closes and the magnetic field in the coil collapses and creates a high voltage to the plug. It's just a magnet and a coil with a plug wire coming out of it - should be simple and lightweight if you don't need an electrical system, and you might be able to mount the magnet(s) on the prop hub...
13,099
Yes, but then you need to buy four coil units. And install them around an 8" flywheel plate (that could be lightened).
It will be fixed timing usually. At 20°.
With Slick mag, just one coil for all four cylinders and an impulse retards for start which allows full power at 28° timing.
I think the Aerovee uses four coils.
BoKu
Pundit
Aug 15, 2013
2,598
Western US
...aren't the ignitions on most industrial engines basically just a magnet whirling past a coil? Ie, no alternator per se, but as the magnet speeds past the coil, it creates a current by induction and the speed at which it grows and decreases determines the strength (voltage), in other words it's the same thing as when a set of points closes and the magnetic field in the coil collapses and creates a high voltage to the plug...
Well, yes and no. Yes, most modern industrial engines have electronic ignition systems that use a magnet and coil to both power the ignition system and trigger the spark. Yes, it is mechanically very simple, and as a result they tend to be very robust. But the electronics in the black box are usually pretty complicated, so overall it might not be the very simple system that you might imagine it is.
Edited to add: The black box usually has some capacity to vary the timing based on RPM using a pre-programmed lookup table.
Thanks, Bob K.
Autodidact
Oct 21, 2009
4,513
Oklahoma
Well, yes and no.
Right, I was mistaken in that the flywheel can only generate the current needed, there is no way that the speed of the flywheel can collapse the field fast enough to generate the voltage needed so they do use a black box, but I think it is relatively simple and just replaces the points with a transistor. There may be more to it, but it is solid state, small, light, relatively inexpensive.
And here is what I was thinking of; there is no room for an alternator in that flywheel, so it is just the magnet and ignition coil/box doing the work. I think you could arrange these components to work on a four cylinder it it were put at the prop hub; say two of these flywheels with a larger diameter phenolic disc sandwiched between them and the four coils mounted in twos, 180 degrees apart:
briggsandstratton.com:
Now for the black box. Magnetron™ solid state ignition systems, in essence, replace the mechanical breaker points with a transistor. That is, we replace a mechanical switch with an electronic one. No moving parts, no arcing, no adjustments and solid state reliability.
ehow.com:
The mechanics of a Magnetron ignition are almost identical to the workings of a breaker-point ignition: a complete circuit on the ignition coil grounds the electrical field it is generating so it stays on the circuit. But, whereas the breaker point system uses a mechanical set of breaker points and cams to push them down, the Magnetron coil uses a transistor to break and close the coil circuit.
HistoryBuff
Apr 27, 2015
1
MOUNT PROSPECT
Topaz, that's a great suggestion. Too often these design discussion threads end up as a lot of different people offering contradictory ideas but we never actually see the design process go from A to Z, which in many cases would show the rationale for the design decisions that sparked the disagreements in the first place.
BREAK
I think I have found the spiritual ancestor to this budget racer, Ed Heath and Claire Linstead 's Tomboy racer, same configuration and 109 mph on the dubious 32 hp of a Bristol Cherub. With the $2,250 or $2,500 in prize money from the 1926 Nationals (reports vary, but that's over $30,000 adjusted for inflation), Heath went on to found the first successful kit airplane company which later evolved in to the famous Heathkit electronics.
View attachment 34594 View attachment 34595
American airplanes: Heath
Aviation Heritage Golden Age Short Stories
Edward Heath is definitely the ancestor for cheap air racing. In fact he started his company well before the 1926 National Air Races, being founded in Chicago around 1911 (the exact date is hard to find). Starting as an airplane parts company, he soon began selling complete aircraft either flyable, as a set of parts or just the plans. After the war, he entered and one events in the 1923 NAR in St. Louis with the Heath Favorite. He later went on to introduce the Parasol and Super-Parasol, the best-selling planes of the period.
Heath continued racing and winning as a way to promote business for his company. Air races were covered in the national newspapers and reached a far wider audience than ads in aviation magazines.
You might be interested in an excellent book, The Heath Story​ by Chet Peek.
7,286
I've always liked the Heath Parasol LNB-4, somehow jauntier and cuter than the longer fuselage and smaller rudder of the Super Parasol.
Swampyankee
Dec 25, 2015
1,419
Earth USA East Coast
Having been involved in car and aircraft racing for a long time- tear downs or the sanctioning body supplying engines for aircraft isn't going to work due to airworthiness issues in most countries.
Real racing should reward those with the best technical skills, innovation, preparedness and driving/ flying skills otherwise it's boring IMO. If you want a spec class, have someone provide 10 identical airframes and engines and choose lots, but this is just about flying skills then. This won't be cheap though. People want to fly their own aircraft I think.
The F1 rules have been around and stable for a long time. This is pretty cheap to get into relatively speaking and you can test your skills against some of the best in the world if that's what you want. Using the same rules, you could set up an F1 race league in your own local area and do cross country stuff like SARL where you don't need the course or the ground infrastructure like Reno.
Fuel limits could work but this turns things into an economy race to some degree although at the same time shows overall cleverness in design and flying skill. This does have the advantage of being relatively easy to police (outside of hidden tanks). With a set airframe spec- wing area and weight, this allows a lot of innovation with layout and engine so it's interesting to designers and builders I think.
Limiting power is really hard to do or police without a ton of time and money.
I've never agreed with penalizing the people winning. This is racing, not a family picnic. The winners are smarter or better so the slower people need to up their game to catch up, otherwise suck it up or go home.
If I put a couple of LM2500s into a 250 ton hull, I'd have a good chance of winning America's Cup. Without some restrictions, it's no fun.
With somewhat less snark, handicapping is a very important consideration in yacht racing, as without it, the largest boat would almost always win.
