Cascade Ultralights Kasperwing
Discussion in 'The light stuff area' started by jedi, Nov 10, 2017.
  1. May 20, 2018 #61
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,775
    466
    krakow,poland
  2. May 24, 2018 #62
    Highflight
    Highflight
    Highflight
    Dec 20, 2010
    155
    25
    North America, Earth, Milky Way Galaxy
    A beautiful machine!
    Unfortunately I have read that the pilot was killed taxi/flight testing the plane.
    I also read that the builder had installed a canard, that would indicate to me that there were pitch problems with the design.
  3. May 24, 2018 #63
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,775
    466
    krakow,poland
    =tapered wing is in controversy to KASPERwings idea...
    (SWIFT LIGHT have only little tapered wings!)
  4. May 26, 2018 #64
    Highflight
    Highflight
    Highflight
    Dec 20, 2010
    155
    25
    Witold Kasper told Steve Grossruck, "a little taper is okay", Kasper never defined how much taper is a "little". Note that Steve's personal Kasperwing ultralight had both taper and smaller swallowtail stabilizers than the production Kasperwing U/L. Steve reported that the changes allowed his plane to have a faster turn rate than production models. The consensus of local KW owners is that the KW U/L turn radius is excellent and tapering the wing adds complexity and reduces wing area.
    YouTube - High Tide 2:17
    https://www.youtube.com/watch?v=eN2rdlbxEj8
  5. May 26, 2018 #65
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,775
    466
    krakow,poland
    -YES!
    but rudder "amplifiers" can help in turbulent weather...
  6. Jun 17, 2018 #66
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,775
    466
    krakow,poland
  7. Jun 18, 2018 #67
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,775
    466
    krakow,poland
  8. Jun 20, 2018 #68
    Highflight
    Highflight
    Highflight
    Dec 20, 2010
    155
    25
    Henryk,
    We have the MZ202 (626 cc) in two of our Kasperwing 180-B aircraft, one is free air cooled the other is fan cooled, they perform very well. The engine manufacturer Compact Radial Engines was located in British Columbia, Canada, the company was recently sold to a Chinese buyer, I do not know if the engine is still in available.
    The two place Kasperwings were fitted with Rotax 532, I think the liquid cooled Rotax 582 would be a good choice for a two place KW.
  9. Jun 21, 2018 #69
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,775
    466
    krakow,poland
    -the thrust force on MZ202 ?
  10. Jun 22, 2018 #70
    Highflight
    Highflight
    Highflight
    Dec 20, 2010
    155
    25
    Henyrk,
    The MZ 202 produced slightly more than the Rotax 503. Both of our MZ 202 engines have belt drives, we have found that the pulleys are inadequate to
    handle the power of the engine and are prone to slippage at higher power settings, I would strongly advise against the using the belt drive option on a MZ 202. A larger belt system as used on the Hirth engine would solve the slipping, I do not know if the output shafts are compatible.
  11. Jun 22, 2018 #71
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,775
    466
    krakow,poland
    -in "auer" MZ202 gearbox with hole (for towing line)...
    -auer muffler is bad "doctored" (for aircraft compartment),we need to made as orginal.
    -du You have a picters of K-W with MZ202 ?
  12. Jun 23, 2018 #72
    Highflight
    Highflight
    Highflight
    Dec 20, 2010
    155
    25
    -Do You have a picters of K-W with MZ202 ?[/QUOTE]
    This is the "Red Baron" KW with the fan cooled MZ-202 and belt drive.
  13. Jun 23, 2018 #73
    Highflight
    Highflight
    Highflight
    Dec 20, 2010
    155
    25
    This is Rotax 583 liquid cooled KW with a Magnum PSRU.
  14. Jun 23, 2018 #74
    Highflight
    Highflight
    Highflight
    Dec 20, 2010
    155
    25
    MZ-202 free air cooled KW using the original factory mounting. The battery failed in two seasons due to engine vibration, it was moved to lower, forward frame tubes to balance the added weight of the larger engine.
  15. Jun 23, 2018 #75
    Highflight
    Highflight
    Highflight
    Dec 20, 2010
    155
    25
  16. Jun 23, 2018 #76
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,775
    466
    krakow,poland
    View attachment 72208 [/QUOTE]
    =I see,only one carburator ? (orginally=2)...
    -how much is climbe (f/min) (m/S) ?
    GREATE THANKS !
  17. Jun 23, 2018 #77
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,775
    466
    krakow,poland
    =2-pilots ? (the frame seems wider,as normal...)
  18. Jun 23, 2018 #78
    Highflight
    Highflight
    Highflight
    Dec 20, 2010
    155
    25
    Henyrk,
    We use only one carb on our MZ-202 engines, we have plenty of power with just one.
    The KW in the picture is standard width, same as all the others we own.
    All of our KWs are single seat, we have no two seat KWs, we do not plan to build a two seat model because it would require FAA (government) registration.
  19. Jun 23, 2018 #79
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,775
    466
    krakow,poland
    =2-place for "normal",old pilots training!
    http://www.samolotypolskie.pl/uploads/Products/product_14422/Kasperwing_Sosnowiec_021.jpg
    -the first attemt...to big wingtips inertia,
    we must rebuild rear spar (52x1 mm)
    and made lighter rudders complex !
    https://groups.yahoo.com/neo/groups...&sortOrder=desc&photoFilter=ALL#zax/430686023
  20. Jun 23, 2018 #80
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,775
    466
    krakow,poland
