So, if the F33 actually weighs 71 pounds and we recalculate, there's plenty of room to upgrade to the F23 and stay within 103 weight. 50 hp could fly a 190 pound pilot in that airplane at 10,000 MSL
First, for the Aerolite 103 they say 235 lbs with the F33 28hp, they don't Specify if with or without the Electric Start. So Airframe could be 190 lbs - 195 lbs.
F33 (28hp) Specs.
No, you got it backward, the
F33 313cc (28hp) is
45 lbs with Belt Drive & Electric Start & Exhaust! It's
40 lbs without Electric Start.
The Aerolite 103 with the
F33 313cc (28hp) is
235 lbs - 45 lbs =
190 lbs for the Airframe. Has an MTOW of 600 lbs.
If Airframe is
235lbs +
30 lbs (Gas) +
190 lbs (Pilot) =
455 lbs = 206.3845 kg / 10 kg = 20.63845 kw needed to Fly Well = 27.67662 hp!
F33 (28hp) 313cc/7cc = 44.7hp if you use a Good Tuned Pipe with 11.5cr, Proper Size Carb/EFI and turn it 6500rpm. +/- 1.0cr = 1.0hp. So with Hirth's 9.5cr -2hp = 42.7hp is possible. A MTOW of 650 lbs needs 40hp to Fly Well.
There is an upgraded Head for the F33, more Mass! I believe it adds 2 lbs. If you use all of the different Engine Coatings you can reduce your overall Temps by 20%.
F23 (50hp) 521cc Specs.
Aerolite 103 Airframe = 190 lbs + F23 (50 hp) 71 lbs without Electric Start = 261 lbs - 254 lbs = 7 lbs to Heavy, so NO, it doesn't make Part 103 unless you put on a $4000+ BRS for it's 600 lb MTOW. You get I believe 24 lbs for the BRS Exemption. The BRS for 600 lbs I looked at a few years ago was 18 lbs. 24 lbs - 18 lbs = 6 lbs. Is there other BRS out today with less Weight, maybe.
I wouldn't want an Engine without Electric Start myself.
In Truth, 36hp will Push/Pull most Part 103 Airframes past the 55 knots Full Power Speed.
A Good Used Rotax 277UL
55 lbs to 65 lbs depending on configuration, Cost $250 to $650 usually with the Gear Drive! Rebuild kit less than $200.
268.8cc/7cc=
38.4hp@6500rpm is possible!
277UL with Gear Drive Rebuilt $850.00 <--- I Paid $250 for my last 277UL with a Gear Drive, so
$450 Rebuilt.
Avg Custom Tuned Pipe for 36-38hp. $650.00 <--- Can you make your own, Yes!
Engine Coatings Avg. $350.00 <--- Can you do your own Coatings to Save $$$, Yes.
Total
$1,850.00
You can
Big Bore the 277UL to Max (82mm x 66mm)
348.6cc / 7cc =
49.8 hp!
A Custom made Big Bore Sleeve Avg $180, the last Blank Sleeve I bought for 82mm off eBay was $40 to make your own.
Custom-made 82mm Piston
$180. An Off the Shelf 82mm Piston Avg
$80. I would use the 670 HO Twin 82mm Big Bore Piston and use the 670/670 HO Longer 132mm Rod which gives it a better Rod Angle and Bigger Bearings with a Special Base Gasket Spacer, $40.
Cylinder & Case Porting can Gain you 10-15% more hp. Avg Cost to have done is $350, can you do it yourself, Yes!
F33 w/Recoil Start $4255.88
F33 w/Recoil Start & Belt Reduction Drive $5285.88
F33 w/Recoil & E-Start w/Belt Reduction Drive $5785.88
Avg Custom Tuned Pipe for 40-42hp. $650.00
Total
$6,785.88
F23 (50hp)
F23 w/Electric Start & Carburetor $9,140.63
F23 w/Recoil Start & Carburetor $8,599.50
F23 w/Electric Start & EFI $11,158.88
F23 Belt Reduction Drive $1,377.68
Optional Oil Injection $415.00
+ BRS $4000.00
Total $15,282.68
For EFI Upgrade. + $2,018.25
Total
$17,300.93
