Can FAR103 Ultralights have retractable landing gear?
Aesquire
Jul 28, 2014
2,687
Rochester, NY, USA
Retractable gear is fine. You can even have a constant speed prop.
Just gotta keep the weight down....and the stall & top speed, fuel & number of passengers.
danmoser
Feb 1, 2010
642
Sandy, Utah, USA
You can have a jet engine, retractable gear, in-flight adjustable pitch prop, flaps, slats, .. etc.
Lots of things prohibited by LSA & other classifications are allowed under ultralight rules.
Basically, all you have to comply with are empty weight (max. 155 lb. un-powered / 254 lb. powered), airspeed (24-55 knots powered), and fuel capacity (5 gallon max.) restrictions... and operate only during daytime while staying out of congested areas / controlled airspace..
FAR 103 is great that way .. lotsa freedom !! :gig:
Aesquire
Jul 28, 2014
2,687
Rochester, NY, USA
IMHO, as a simple matter of practicality, retract gear on any aircraft needs a good reason for the mass and complexity.
At speeds under 70 knots, the percent improvement in speed isn't worth it. On a Lancair? Your call.
It does make sense in a motor glider, for L/D improvement, but you have to consider it as part of the overall drag bucket. Good fairings might be a better choice.
Amphibians, for obvious reasons.
Fighter replicas just for looks.
Because you want to.:)
14,761
If foot- launched, retractable undercarriage might be fairly simple. :gig: Birds do it.
Vipor_GG
Jun 8, 2013
850
Cayce, SC / USA
Unless you are going amphibious I don't see the need. The plane has to weigh in under 254lbs. That's hard enough to meet without adding something that really isn't needed.
8,768
Because of the restriction in maximum cruising airspeed, you would be hard pressed to find a case where retract gear is justified on a powered aircraft. At 55 MPH the reduction in drag is not very significant.
Because of the weight, you would be hard pressed to find a case where you can afford the extra weight on a 155 pound glider.
One of the long-established tenets in glider design and soaring is that a well-faired fixed gear is much lighter and often lower drag than a mediocre retractable gear.
billyvray
Aug 17, 2005
843
Newnan, GA
Many on this thread are correct that it's totally not worth it.
But it's cool. At least until you forget to put the gear down....
Bill
