Good afternoon Gents! what are most guys using for cams? stock or a just a bump over stock?
T tomz28 Active Member Joined Mar 14, 2021 Messages 25 Mar 19, 2021 #1 Good afternoon Gents! what are most guys using for cams? stock or a just a bump over stock?
Pops Well-Known Member Supporting Member Log Member Joined Jan 1, 2013 Messages 10,676 Location USA. Mar 19, 2021 #2 For straight drive at prop rpm's it's hard to beat the stock cam. Want low rpm torque not high rpm hp.
K karmarepair Well-Known Member Supporting Member Joined Jan 13, 2011 Messages 728 Location United States Mar 19, 2021 #3 Use ratio rockers to get a little more lift. Schneider cams has a grind developed for wind machines to protect orchards the works great if you really want to spend your stimmy check.
