Briggs & Stratton 993cc "Big Block" engine conversation thread
Stuffengineer
Apr 7, 2020
48
Sorry to hear that Ken. Hope your better soon.
Stripped down a 40 so no flywheel or stator/regulator all tin starter etc. Only thing I left on was the intake and EFI components, oil cooler/filter and full oil.
Weight was 80.5 lbs 36.4kg.
Ken Powell
Dec 8, 2020
50
Bryant, AR
Stuffengineer - that is great info on the taper. Now I know what to ask Arrowprop. Did you strip a 40 HP engine or a 40 cubic inch engine? Longblock weight of 80.5 pounds would give me 20 lbs for prop hub, ignition system, exhaust, intake and carbs.
Stuffengineer
Apr 7, 2020
48
HP. Engine still had intake throttle body harness injectors etc.
Ken Powell
Dec 8, 2020
50
Bryant, AR
PTO is 2.25 taper per foot
3.8” total length.
I do not have the engine yet and I am trying to confirm the taper dimensions. And yes, I need to make a few phone calls to confirm engine crank taper and Arrowprop capabilities. On your engine: What is the 'large' diameter of the crank before the start of the taper? Where does the taper start?
Ken Powell
Dec 8, 2020
50
Bryant, AR
I have ordered an engine.
61E377-0027
This engine has the 'pink' valve springs (and I think the steel pushrods) and shares many parts with the 40 HP Marine engine.
I also ordered:
J609B Shaft Sleeve Adapter 7/8" Tapered Shaft Into 1 7/16" Diameter Straight Shaft
J609B Shaft Sleeve Adapter 7/8'' Tapered Shaft Into 1 7/16'' Diameter Straight Shaft Keyed | Tapered Shaft Sleeve | J609B Sleeve
The idea is to be able to use either a tapered prop hub or a 1-7/16" taper lock hub.
The Arrowprop website has disappeared. I'll give them a call tomorrow to see if they are still providing prop hubs.
Question: What prop flange pattern for the hub?
1. 75mm Rotax
2. 3-1/8" 1/2 VW
3. 4" VW
4. SAE 1
karmarepair
Jan 13, 2011
728
United States
Ken Powell
Dec 8, 2020
50
Bryant, AR
What I really need is a hub with an inside taper to replace the flywheel. My 9" Southbend lathe (built in 1932) does not have a taper attachment (but is tight and will hold a 0.001 runout tolerance). Any ideas on where I might find a flywheel hub for a 993cc? Maybe ARC?
blane.c
Jun 27, 2015
5,919
capital district NY
Yes hub taper is short and compound will do it. The taper can be divided into 3 sections, the small end and the large end and a section in the middle. The middle section does not have to have contact with anything, it doesn't matter. The small end and large end need to have proper contact.
Stuffengineer
Apr 7, 2020
48
I wouldn’t put prop on flywheel side. Check into what bearings are in that particular model. I think it is only a sleeve bearing on flywheel not sure about pto end.
Stuffengineer
Apr 7, 2020
48
Each different model build will have something different. OEM’s will have there own model number and can spec what bearings crank etc. They have more choices than you buying one off the shelf.
rv7charlie
Nov 17, 2014
2,837
Pocahontas MS
Most use sleeve bearings on both ends, but the PTO end is designed for bending loads.
Lyc crank:
'industrial engine' crank (flip the image to align the pto end with the Lyc's prop end):
Ken Powell
Dec 8, 2020
50
Bryant, AR
The prop will be installed on the PTO end. I am removing the flywheel and starter. I plan to use an aluminum disk on the flywheel end for the HEI ignitions (separate ignitions for each cylinder and 2 pickups for each HEI system. One pickup at 12 degrees BTDC and the second at 28 degress BTDC. Start on the retarded pickup then switch to the advanced pickup.
Ken Powell
Dec 8, 2020
50
Bryant, AR
I'm a real amateur when it comes to machining and had not considered using the compound to cut the taper. I have some 2" 6061-t6 aluminum round stock to use for practice.
Ken Powell
Dec 8, 2020
50
Bryant, AR
I received my Briggs Big Block (993cc) last Friday. Here is the engine I ordered: 61E377-0027
This engine has a tapered Crank and is 37HP EFI. Delivered weight was 124.65 lbs. I then stripped it down to the long block (removed the EFI, flywheel and everything else except the oil cooler). Hold onto your seats - the long block weighed 68.05 lbs. I'll weight individual components later this week.
I also did some parts comparisons with the 61G 40HP Marine engine. The head, intake valve, retainers, keepers, valve springs (pink) and push rods are all the same part numbers. The rods and the rod bolts are the same. The exhaust valve is different. The camshaft and pistons are different. The EFI appears to be the same except for different mapping of the ECU.
