Boeing - Design Issues...
10,457
The parts in that article not being made to spec would be but a fraction of the total quality issues each plane has, with some being identified and corrected in a way deemed acceptable by engineering, while plenty others go unnoticed/unreported unwittingly or otherwise. By what I've heard from friends that work at Boeing's old Wichita plant now owned by a supplier producing the 737 fuselage, it's a mad house which is not surprising considering how short of a time they've been given to ramp up production to 50+(!) units a month. People are overworked, there's not enough inspectors (an effective way to have worksmanship issues overlooked), along with deadlines that have significant financial repercussions if not met which further fosters a culture of letting problems slide.
One of the side effects of a booming economy. Could be corrected by the owners, and probably will be, once they conclude that the high production rate will continue long enough to justify the additional cost.
It also doesn't help when the off-shifts tend to be primarily staffed by people with the least amount of experience, so you have huge skills and knowledge gaps between the shifts which creates issues some companies seem to underestimate.
Is that driven by union rules or management rules?
The only thing that gives me comfort when flying is the hope that the plane had been over-engineered.
The safety record for commercial air transport in the USA, as previously noted by others, remains better than traveling in automobiles.
mcrae0104
Armchair Mafia Conspirator
Oct 27, 2009
3,139
BDU, BJC
Feel free to show us why or where the video information is flawed, or non factual. That would help me, and everyone else here.
I would love to help, but I quit watching when the star witness said, "Nobody cared about the safety aspect." I don't know about the validity of anything that followed, but it had the fearmongering tone of a Dateline story blowing up pickup trucks (with assistance from model rocket engines) and so I didn't bother to give them my time.
12notes
Aug 27, 2014
958
Louisville, KY
0,0003333... could be a common tolerance. Check SI measurement units and tolerance, round to nearest US measurement. To be able to procure parts internationally, Boeing must have the drawings in SI units. Note that most CNC machines default to SI units.
It works out to 0.0762mm. I'm not sure if 0.07 or 0.08mm are common tolerances, but I haven't seen either before. 0.05mm I've seen, but it's about 0.002" (.00197).
EDIT: I goofed and calculated .003" instead of 1/3000th here. 0.003" = 0.0762mm.
1/3000 of an inch is 0.00847mm.
ScaleBirdsPaul
Jul 6, 2015
37
Connecticut
I'm pretty sure they mean 3/1000th of an inch or .003. I believe that what they reported may be factually true but I don’t trust that it paints an accurate picture.
Himat
May 5, 2011
2,861
Norway
0,1mm and 0,05mm are common tolerance to see on a drawing. With SI units any step of 1 can and is probably used so 0,07mm or 0,08mm is not strange. 0,075mm is half of a 0,15mm tolerance and that one could be considered common.
12notes
Aug 27, 2014
958
Louisville, KY
I just realized I had converted .003", 1/3000" is actually 0.00846mm. I corrected my previous post.
But realistically, I'm pretty sure my original interpretation is correct. 1/3000th of an inch is just plain awkward and I've never heard anyone use fractions in inches like that, just powers of 2 in fractions (and usually no smaller than 1/64") or decimal.
TXFlyGuy
Apr 25, 2012
1,585
Republic of Texas
Yes, the old Firestone / Ford tire controversy. Car & Driver pretty much put that to rest, after they did just what you said...placed a charge in the wheel well, and blew up the tire at highway speed. The Ford Explorer did not flip over. And it was controllable throughout the deceleration.
gtae07
Dec 13, 2012
1,878
Georgia
If it's anything like my employer, probably neither one. It's just a consequence of the hours. Even with a nice shift differential it's often hard to find people for second, third, and weekend shifts; typically all you find are single people, guys with very young children and stay-at-home wives, or old guys whose kids have moved out. It's even worse when you get to engineering; very few engineers are willing to regularly work an off-shift and it's nearly impossible to fill those slots if you're only allowed to hire internally.
Then again, we don't rotate people on and off of different shifts. You hire in for an off-shift and you typically stay there for a while.
I'm coming up on two years of weekend shift and I probably have about two more to go before I go back to regular dayshift as my son starts kindergarten.
markaeric
Jul 31, 2015
346
Wichita
Sure, but expansion takes time even if it is to happen, though what might happen in the future can't really affect what might happen in the meantime.
gtae07 elucidated on the reality of the nature. First off, I'd just like to mention that there certainly are some very skilled employees on the off-shifts (these tend to be people who actually want those particular hours), but the proportions are worse compared to the primary shift. Whatever the rules are, they're ones that have been agreed upon by both union and management, assuming it's a union shop, and at least around here the union isn't all powerful. I suspect that if management wanted to throw in some way of incentivizing senior employees to work off shifts, they probably could get it in the contract, but they'd rather just bellyache about the higher proportion of quality issues coming out of those shifts. Now what if you could force them to do it? Well, either they'd jump ship or you'd ruin morale. Not a good way to treat your good employees, is it?
As for the lowest level managers, most of them give no consideration to someone's ability when assigning them to a task. Job X needs to be assigned to someone? Whoever the next warm body in line is will fill the vacancy. It seems like common sense, but over and over I see people assigned to a task they're ill fitted for, and the foreman doesn't even think twice about it. I wish I had the opportunity to see how our non-union shop operated. I bet it wasn't significantly different.
No argument here. What I was getting at is luckily airplanes aren't generally built with razor-thin margins, so that common unaccounted for manufacturing/maintenance defects such as material gouges, dents, out of tolerance holes, fastener installations not to spec, mislocated parts, etc - all issues that I imagine most production planes have to varying degrees, doesn't automatically bring a plane down in its lifetime.
12,220
Those ill suited workers in a union shop become shop stewards and do even less. Good foreman will make those bad workers work, the bad foreman hide those workers and over work the good ones. The bad workers knew how much to screw up so they would get put back on checking tire pressure but not enough to get fired. I worked with some professional bad mechanics.
markaeric
Jul 31, 2015
346
Wichita
I meant more along the lines of some people being tasked with performing functional tests who have no business doing that because they can't troubleshoot worth a sh_t, while some other technically savvy person is tasked with mindlessly installing cabin insulation and baggage panels. A good foreman utilizes his resources effectively. Unfortunately, most foreman are not particularly good.
10,457
A frequent mistake is to select a group leader based on either seniority or technical skills. Neither is an indication of the leadership skills required for the job. Would also note that neither is a disqualifier, and the technical skills are a big plus IFF complemented with the leadership skills.
gtae07
Dec 13, 2012
1,878
Georgia
Well, it wasn't actually me you quoted but agree 100% with your statement.
13,249
""The crew performed all the procedures repeatedly provided by the manufacturer but was not able to control the aircraft," Dagmawit said, citing data from the Boeing 737 MAX 8's recorders."
I heard something the other day from a friend who has connections with many 737 pilots. Perhaps someone here can confirm or refute this.
According to his resources, the MCAS was originally designed with 0.8 degree max stab change to avoid excess overtrim, but that was found insufficient and later changed to a maximum of 2.x degree degree max stab movement (I think he might have said 2.4 degrees). However, after the MCAS stab limit is reached and if the pilots shuts the system off, then back on, the system resets to zero and then allows another 2.4 degree stab movement.
I’m not one to take heresay as gospel, but at least this one sounds feasible.
SVSUSteve
Aug 20, 2007
3,893
Evansville, Indiana
It was an older 737, Aloha. Blew it's top. I heard the inside story on this...the auto pressurization system was inop, so the crew had to run it in manual. They accidentally over pressurized the cabin, and the relief valves failed.
Not really a fault of the airplane.
That's absolutely not what happened. It was a fatigue failure, poor oversight, etc. https://en.wikipedia.org/wiki/Aloha_Airlines_Flight_243
It is worth noting that the minority opinion of at least one NTSB member laid part of the blame on Boeing for failures to maintain exercise due caution for aircraft operating in environments where high cycles and increased corrosion risk line up (read as: closely interspersed islands like Hawaii).
TXFlyGuy
Apr 25, 2012
1,585
Republic of Texas
You are correct, in the fatigue statement. But the primary contributing factor to the accident was the crews improper manipulation of the manual pressurization controls. In conjunction with the failure of the relief valves to function as designed, causing the ultimate "convertible 737". Due to PC issues, much of this was swept under the rug. Or so I'm told.
Perhaps this was just made up? Don't know. But I could not find any info on MEL's the plane might have had at the time of the flight.
If the auto pressurization system was fully functional at the time of the flight, then the above is just another bad rumor. Started by a male pilot, no doubt.
