Bending Brake issues
Discussion in 'Workshop Tips and Secrets / Tools' started by 12notes, Nov 4, 2017.
  1. Dec 10, 2018 #41
    Armilite
    Armilite
    Armilite
    Sep 6, 2011
    3,191
    275
    AMES, IA USA
    Seems like a Lot of work to build one, if this may work for you.
  2. Dec 10, 2018 #42
    4,050
    1,187
    the one you show would not bend it either...trust me
  3. Dec 10, 2018 #43
    dcstrng
    dcstrng
    dcstrng
    Oct 17, 2010
    913
    323
    VA or NoDak
    Mine is sort of the cobbled together “Dave” brake – used heavier door hinges rather than piano-hinge and also use heavy C-clamps (which means I cannot do middle of a sheet bends, except with really light stuff), then bolted the whole thing to the wall… It would do 0.032 6061 at 96” length in its original config -- I eventually welded on more leverage and then was able to do 0.040 2024 at the same length – took it in stages but it came out better than I’d hoped although, regrettably I no-longer have a project that needs it – just wanted to see if it might, and it does… good clamping and enough leverage and you can bend nearly anything reasonable at home, I think…
  4. Dec 10, 2018 #44
    12notes
    12notes
    12notes
    Aug 27, 2014
    913
    561
    Louisville, KY
    My brake has a number of advantages over the Harbor Freight one:
    1. My brake is twice as long, with a 72" bending area (78" if it's less the bend is 1" or less from the edge.) The HF one is 36", the test piece is 40" long, it can't even fit, let alone bend, the piece in question. It's a non-starter for thinner 6' wing skins.
    2. The HF brake would use up valuable floor space in my garage, which I'm having difficulty moving around in now. My brake can be unbolted from the table and thrown under my tool box.
    3. My brake is already built and was $90 cheaper. It was not a lot of work, it took 8 hours to build total, but my hobby is building things anyway, so I can't really count that time as a cost.
    proppastie likes this.
  5. Dec 11, 2018 #45
    narfi
    narfi
    narfi
    Feb 23, 2016
    789
    398
    Alaska
    I can stand on the feet of the brake I use at work, and since I cant lift myself up it doesn't need to be heavier than I can lift.
