bending a wing spar
Discussion in 'Sheet Metal' started by quickcut, Mar 21, 2018.
  1. Mar 21, 2018 #1
    quickcut
    quickcut
    quickcut
    Feb 16, 2015
    15
    1
    south africa
    I am building a 750 cruzer. The main wing spar is too long for my press brake and I would like some input as I would like to stagger bend it(the spar) . By this I mean bend say 15 degrees ,then move the piece up and bend the remainder , increase the bend angle and repeat the process till the whole spar is bent. Comments please, thanks
  2. Mar 21, 2018 #2
    11,137
    3,017
    You might be able to do it in 5 degree increments. You defiantly don't want to have a point identifiable as the stop start point in the bend.
    pictsidhe likes this.
  3. Mar 21, 2018 #3
    Turd Ferguson
    Turd Ferguson
    Turd Ferguson
    Mar 14, 2008
    4,555
    1,554
    Upper midwest in a house
    People used to bend spar flanges for legacy aluminum homebuilts and whatnot by hammering the flange over a wooden form block.
  4. Mar 21, 2018 #4
    5,757
    4,624
    I thought the Zenairs all use angle extrusions for the spar caps...?
  5. Mar 22, 2018 #5
    11,419
    2,095
    You might try hammering the flange while holding down pressure in the press.
    That might avoid pressing a kink at the end.
  6. Mar 23, 2018 #6
    Wayne
    Wayne
    Wayne
    Jan 15, 2013
    402
    496
    Chicago, IL
    My factory made spar used extrusions.
  7. Mar 23, 2018 #7
    5,757
    4,624
    So what do the plans show? Do the plans show a bent spar or a flat sheet spar with angles riveted to the sheet?
    I am confused by all this... what exactly needs to be bent on the main wing spar if you are building a Cruzer?
    BoKu likes this.
  8. Mar 24, 2018 #8
    quickcut
    quickcut
    quickcut
    Feb 16, 2015
    15
    1
    south africa
    Your'e right it is extrusion. I just had a quick glance and thought how am I going to bend that.
    thanks
  9. Mar 24, 2018 #9
    8,887
    5,737
    Isn’t the rear spar bent from sheet?
  10. Mar 24, 2018 #10
    Turd Ferguson
    Turd Ferguson
    Turd Ferguson
    Mar 14, 2008
    4,555
    1,554
    as is the rudder spar, stab spar.....??
  11. Mar 24, 2018 #11
    harrisonaero
    harrisonaero
    harrisonaero
    Oct 31, 2009
    536
    265
    Coeur d'Alene, ID
    It's not rocket science- clamp and then bend over the edge of a table with a mallet a little at a time. Nothing says it has to be brake formed.
    wsimpso1 likes this.
  12. Mar 28, 2018 #12
    3,511
    1,006
    better practice on some scrap....hardened material is not easy to keep straight. if you practice with soft steel it is not the same......you might decide to get it properly bent in a brake....but careful.... most heating air conditioning guys do not know the meaning of the term "bend radius" and you could end up with expensive scrap their machines are usually set up for sharp bends on soft steel.....a "no no"
    MadRocketScientist likes this.
