Balancing two Bing 54 Carbs on a Rotax 503
Tuneturkey
Dec 29, 2018
68
10113, Hyde Park Ct., Baton Rouge, LA 70816
As a alternate to using a manometer to balance the two Bing 54's, is is possible to use a Dwyer, diff. pressure ga, 10 inches of water max rating, to do the fine tuning on the balance. Can't find the manifold suction pressure rating for the 503, but I suspect it is in line with the impulse pressure, around +/- 2-3 PSI, which is much in excess of the 10" water, but doing a mechanical balance with the slide pistons, to get close, then a fine tune with the Dwyer Ga.
Comments,
Thanks
kent Ashton
Aug 15, 2008
739
Concord, NC
An idea from motorcycles: Small diameter clear vinyl tube formed into a circle with a B-B in the bottom of the loop. Differential suction displaces the BB. It is fairly sensitive.
4,514
I have one of those mercury balances..before that I would just hold my hand close to each carb inlet, and/or at the end of each exhaust. Any pressure gauge could work including a clear water tube with colored water. Never used the Dwyer....long time ago seemed to be 4 to 8 cm of mercury on a big 4 not sure about that though.
Hephaestus
Jun 25, 2014
1,661
YMM
My instinctive answer is you should check your local MG, triumph or Norton club.
Sorry best carb synchronization comes from octogenarians who use nothing but basic hand tools and no fancy gauges (sometimes they come out, but if they do you know you've got other problems) most likely will cost you rye or a case of labatts around here :)
Jim Chuk
Mar 30, 2013
111
Chisholm Mn USA
Another way is to watch this utube video, and do like this guy is doing., I'm going to make a set up like this for my 912. What I did so far was run a line from each manifold to a T, with one end of the T going to a large vacuum gauge. I had a shut off valve in each line coming from the manifolds, and would open one while the other was closed, get a reading and then reverse the valves to get a reading from the other side. JImChuk
Bill-Higdon
Feb 6, 2011
590
Salem, Oregon, USA
delta
May 26, 2011
2,132
Brookside Utah
Make sure that what ever method you use, you also check the synchronization at partial throttle. Sometimes a small diameter hose between the carb and your ear will do in a pinch.
