Bad slosh sealant in a leaking wet wing
rjgritter
Jan 2, 2021
19
Hi all,
I've got a project airplane with metal, wet wings that has a few problems. First, I'm told at least one wing has a small leak. Second, and the reason I haven't even tried to verify the first - it appears that someone tried to fix that leak by sloshing the tank with Red-kote, which is an automotive slosh sealant. I'm not certain that's what they used, but it's certainly red, and that seems to be a popular choice.
The big problem: the sealant coating is visibly coming loose just inside the fuel cap. I haven't borescoped the tank yet to see how bad it looks everywhere else, but if it's flaking loose right under the cap, I'm not optimistic. I'm concerned that as sealant flakes off, it'll fairly quickly clog the fuel system.
There's no practical way to gain physical access inside the wing to clean this stuff out manually.
My first thought would be to attack it with acetone or MEK to soften and wash out the sealant, but: the wing construction is bonded with ProSeal in addition to being riveted together. The ProSeal is both for primary sealing of the tank as well as structural reinforcement. I'm fairly certain that MEK in the tank would ruin those bonds. I see some anecdotes that ProSeal is fairly impervious to acetone. If true, perhaps that would be a good choice?
I'm eager for any suggestions one how to tackle this!
Thanks in advance,
RJ
