B&S 49-series (810cm3/49ci) for aircraft use - TiPi's Q&A thread
Discussion in 'Firewall Forward / Props / Fuel system' started by TiPi, Oct 4, 2019.
  1. Oct 24, 2019 #81
    karmarepair
    karmarepair
    karmarepair
    Jan 13, 2011
    65
    19
    United States
  2. Oct 24, 2019 #82
    karmarepair
    karmarepair
    karmarepair
    Jan 13, 2011
    65
    19
    United States
    Common US pump like that http://walbrofuelpumps.com/walbro-gsl395-fuel-pump.html May be bigger than needed. Lots of these applications put the pump IN the tank.
    It looks like Jan mounted this right over where the PTO used to be.
  3. Oct 24, 2019 #83
    karmarepair
    karmarepair
    karmarepair
    Jan 13, 2011
    65
    19
    United States
    True. From Carrol Smith's "Prepare To Win": IMG_20191024_084000993_BURST001.jpg
  4. Oct 26, 2019 #84
    JohnB
    JohnB
    JohnB
    Aug 18, 2019
    29
    28
    Zero experience with dry sumps, at least I don't remember any in the last 60 yrs of wrenching.
    I'm guessing that the return hose I.D. size will have to be fiddled with as we are using blowby to make it happen, too large will let the gas pass without moving the oil much and too small will be restrictive ...... or am I creating an issue where there is none?
    JohnB
  5. Oct 26, 2019 #85
    TiPi
    TiPi
    TiPi
    Aug 25, 2019
    161
    155
    Mackay (AUS)
    Quite right John, I'm looking at 8-10mm at the moment. The 912 uses a 12mm (1/2") hose for all oil lines (suction & return). Next 5 year rubber replacement is coming up so will have to source all of those hoses again. The oil line on the Briggs is 8mm (to the oil cooler), so oil suction line will also be 10mm to start.
  6. Oct 29, 2019 #86
    karmarepair
    karmarepair
    karmarepair
    Jan 13, 2011
    65
    19
    United States
    This rather nice gear pump I found on e-bay is also rather heavy.
    New message from: gkwholesale
    ~5.75 lbs.
    Your previous message
    What does your pump weigh?
    Electric Scavenge Gear Pump 12 volt Turbo Oil Evacuation New 12v BEST DEAL
    [​IMG]
    Price: $87.99
  7. Oct 29, 2019 #87
    4,240
    1,973
    We only need a few ounces, right? Enough to fill the pump chambers and the pickup tube? Wouldn't a manual stroke pump (like a fuel primer for a carb) do the trick? Cheap.,light, and reliable.
    akwrencher likes this.
  8. Oct 29, 2019 #88
    TiPi
    TiPi
    TiPi
    Aug 25, 2019
    161
    155
    Mackay (AUS)
    Better option would be a manual priming pump from an old-fashioned mechanical diesel (stil need check valves in the line as well).
    Vigilant1 likes this.
  9. Oct 29, 2019 #89
    7,217
    2,060
    What's the fascination with electric everything? It's heavy!
    [​IMG]
    poormansairforce likes this.
  10. Oct 29, 2019 #90
    6,536
    2,459
    Why the fascination with a priming pump?
    Just keep the top of the oil level in the tank at, or slightly above, the oil pump. It then stays primed*. The only leakage is going to be around the oil pump drive shaft and that will all flow between the cylinders so there will be no hazard from hydraulic lock. Of course this presumes a Rotax style dry-sump rather than simple gravity drain.
    * presuming a sealed system that can't draw air, and you don't turn the prop backwards - just like the Rotax system
  11. Oct 29, 2019 #91
    litespeed
    litespeed
    litespeed
    May 21, 2008
    1,530
    310
    Sydney
    I agree with as simple as possible, also tends to be cheaper and lighter.
    It just needs a few ounces and be heat proof to low degree, check valves in the right places can ensure it only feels cold oil on startup. For reliability it should only have flow on startup then be isolated.
    A simple plunger/syringe could do it. The bulb could if done well.
    Its not the price that offends with having a electric pump but the weight and failure potential. Unless we get heavy most will be like a fuel pump and not really suited. That begs the question, can it be done with all the advantages sought from electric and be light and safe enough?
    How much weight are you prepared to compromise?
  12. Oct 29, 2019 #92
    7,217
    2,060
    I'm going to fix the briggs pump so that it will self prime. Lightest and most reliable, but not the easiest. It will need a plate with accurate ports put in the bottom of the pump cavity.
  13. Oct 29, 2019 #93
    Hephaestus
    Hephaestus
    Hephaestus
    Jun 25, 2014
    1,382
    313
    YMM
    Just how long do you expect that will last? Subjected to hot oil - that's not going to survive very long. And it would have to be outside thr primary oil loop as it likely wouldn't hold together at operating pressure.
    I'd plan to do some serious testing before i hopped into an aircraft with that setup.
  14. Oct 29, 2019 #94
    6,536
    2,459
    Just realized we have commandeered TIPI's Q+A thread.
    Unless it is directly related to his project we probably should be using the other B+S threads?
  15. Oct 29, 2019 #95
    7,217
    2,060
    Well, if I used one from a major car manufacturer, it should outlast the engine. It goes in the suction side. I'd be far more dubious about a lot of the electric solutions proposed.
  16. Oct 29, 2019 #96
    TiPi
    TiPi
    TiPi
    Aug 25, 2019
    161
    155
    Mackay (AUS)
    Just be careful, these ports have been cut for a reason.
    One possibility to assist with priming is the fact that the V-twin has a pumping action in the crankcase of approx 200cm3 per revolution. If the oil/air discharge line contains a check valve (as I have planned), there will be a slight vacuum at every turn when pulling the engine through. This will assist greatly with pulling oil from a tank that is a bit below the pump inlet. It will only work in a dry-sump system with a vented tank and a sealed crankcase. It would involve some trial and error to work out how many turns the engine needs to prime the pump when dry (a clear suction hose will show quickly what it takes).
    I would not use any rubber pump that is not designed for 120deg C oil!
  17. Oct 30, 2019 #97
    7,217
    2,060
    The ports are cast, not cut. The reason being that it is cheapest and fine for an immersed pump. I'd put money on horizontal engines having much tighter ports.
  18. Oct 30, 2019 #98
    DRFlyer
    DRFlyer
    DRFlyer
    Aug 8, 2019
    8
    4
    Detroit Area, Michigan
    I'm fairly interested in using this engine on an HM293, actually saw one on Pouguide.org with a redrive so I guess it's been used before. Looking to drop some weight and complexity, do you think this engine could be modified in a way where it could be hand-propped? It looked like the starter was overly beefy, and it would be nice to just forego a starter battery and heavy cables.
  19. Oct 30, 2019 #99
    4,240
    1,973
    Are you using a PSRU? You wouldn't be able to hand prop through that. In direct drive, the question would be whether you could spin it fast enough to generate a spark using the magnetrons. I haven't seen a hand-propped Briggs.
  20. Oct 30, 2019 #100
    TiPi
    TiPi
    TiPi
    Aug 25, 2019
    161
    155
    Mackay (AUS)
    Hand-propping a Briggs would require a few mods:
    • Remove the decompression mechanism in the camshaft
    • Have a heavy prop
    • Depending on carburetor location, add a fuel primer
    • Ideally, have an ignition coil with retard for starting (25deg BTDC is difficult to overcome consistently)
    At the point of the magnet passing the coil, the engine speed would need to be >250rpm
    Not impossible but I wouldn't trade the risks involved for the weight gained. Adapting a lightweight highspeed starter motor and Li-Fe battery are the safer option. You also need to look at the mass of the airframe and what hand-propping would do to that (balance)?
