Lee Schaumberg
Hello
Many fly with automotive spark plugs. The problem is knowing what heat range to use to prevent any chance of engine damage. The champion plugs for the engine are the proper heat range but what is it? 17.00 versus 3.00 dollars a plug is a good reason to change. Using the proper coil to plug wire eliminates any RFI so using that solid state ignition system is easy. So if you use automotive spark plugs tell us the plug , engine , and how well it works!
