Attachment details for pre-sewn coverings, UVPT/Technora/Hydranet
Mavigogun
May 29, 2016
80
Progressive Texas
Hang glider manufacturers employ pre-sewn coverings of Dacron, UVPT/Technora/Hydranet, etc, held in place with pockets, straps, screwed grommets. A few conventional aircraft also employ finished-removable coverings, such as the BushCat. I’m looking for details of attachments for such coverings, including novel tensioning devices, transitions to ridged coverings/fairings/canopies.
Thus far, references include hang gliders featuring velcro, cords, cammed levers, screws, cords, straps, pockets, and zippers. I’m particularly concerned with transitioning from leading edge d-cells and the like, and around fixed portions of canopies. Any insight will be appreciated.
Mavigogun
May 29, 2016
80
Progressive Texas
Pictured here is a riveted dog-toothed strip employed to receive and space stitching connecting trilam around the BushCat cockpit:
Here, the elevator sail is slipped over the frame and laced tight:
Mavigogun
May 29, 2016
80
Progressive Texas
Pictured here are rib-end levers inserted into a wing trailing edge that act to secure and tension the sail on the Impact hang glider:Impact trailing edge tension.JPG
Same aircraft, a lever used to tension the aileron covering:
...and here, the aileron and wing trailing edge together with levers in place:
A view of the scheme from inside the sail:
Here we see ribs Velcroed in place on the aileron spar, allowing them to swing into tension within the sail:
Lastly, root anchor hardware fitting over studs, attached to the sail by straps:
D_limiter
Jul 13, 2018
121
Norcal
I'm interested in this covering technology. The Bushcat is the only LSA I know of using it. If you find more info, I'd be interested in hearing more.
REVAN
Dec 6, 2016
224
Tucson, Arizona USA
Likewise- post illustrations of what you discover here.
Indeed. I think there are many of us interested in this subject. From the replies, it appears there are many more people looking for information and details than there are people who have the information to offer.
REVAN
Dec 6, 2016
224
Tucson, Arizona USA
@Mavigogun - Did you see what Bushcat is doing regarding the laces and holes in the fabric? Do they just melt holes with a soldering iron in the tri-lam for the laces, or is there some form of reinforcement added to keep the tri-lam from tearing out? I can't see these details in the photos you posted.
Mavigogun
May 29, 2016
80
Progressive Texas
In most cases- at control surfaces edges -they are just melted, as I recall. I slowed down this video, I think, for taking stills from- you’ll want to mute it:
