John Newton
I have been toying with the idea of trying to create a formula that will give a good approximation for the neutral point of a linearly tapered and swept wing allowing for sweep effects.
I have based it on the C-point calculation used by Dr. Panknin, the Hortens, K. Nickel etc. (this assumes the lift is centred on the quater chord point for the entire wing). The C-point is simply the quater chord point of the Mean Aerodynamic Chord of the wing.
I would be very grateful if anyone has any data they can point me toward concerning true neutral points of sweptback wings so I can see how accurate my formula is for varying sweep, taper and apect ratios. Also if anyone has an existing design with a known neutral point if they could pass on the wing data and I will again compare it against the neutral point my formula predicts.
My idea is to produce an equation that is more accurate than the C-point for moderately swept and tapered wings. It is based on figure 2.7.5 on page 84 of Tailless aircraft in theory and practice. This is data for a wing with an apect ratio of 10 and a sweep angle of 15 degrees but I am hoping it will still provide a good approximation for other values.
The equation is as follows:
Yn/semispan = (Yc/semispan)-(((Zx2)-1)x0.04) approximately
Where:
Yn = Spanwise distance from wing root to Neutral point
Yc = Spanwise distance from wing root to C-point
Z = taper ratio
Thankyou to all the people that have helped me so far, particularly Norman, Topaz and Autoreply, any help or suggestions on the above would be very much appreciated.
Where:
Z = taper ratio
