Anyone made a 1/2 VW with both cyls on one side?
4trade
Nov 1, 2010
527
Lahti/Finland
Its my understanding that a full size vw engine or 4 cylinder wieghs only a few pounds more then a half case vw with all things being equal.
You was talking 4 cylinder engine in your topic. Not 4 cylinder engine block at 2 cylinder conversion.
9,026
I built a 1/2 cut case, VW engine a few years ago. It weighed 89 lbs. A 4 cylinder VW 1600-1835 cc, short block engine will weigh 116 lbs. My 1835 cc, 60 HP VW engine firewall forward weight is 141 lbs, (no electrics).
I was told by a friend of mine that has built several 1/2 cut case VW engine and several full case 1/2 VW engines and he said that you saved about 7 pounds by cutting the case. Don't know how accurate . You are really just cutting about 3.5" off the case and the real weight saving is the cut crank and cam.
BTW-- I saw a 1/2 VW at OSH years ago, that used one side of the engine. Didn't see it run.
N8053H
Jan 31, 2013
2,523
Those numbers sound right. As you see it just is not that big of savings to write home about. Then if you add a starter it gets back to the average 4 cylinder weight.
I run a starter on my 1/2 vw, I have the 40 hp version with full flow oil filter and oil cooler.
M
mate88
While reading the notes above I realized that in my youth I rode many an older Brit bike (BSA, Triumph etc.) on and off track, and they had 2 cyls on top (= side). Called in-line twins and all ran pretty smoothly. Difference is that they had 360 degree cranks. I.E both pistons rode up-down together with a bang every rev, one side then the other 360 deg later. Of course they also had pretty hefty counterweights on the crank but with careful prep you could run the Triumph up to 6K regularly. Many road racers used these in the 50's and 60's then Yamaha happened!!
9,026
First bike I rode was a Triumph and then a BSA. Never could decide which one I like the best. Dan
Brian Clayton
Dec 7, 2012
1,042
Ivey, Ga and Centerville,Tn
I have a some triumph stuff at the shop....it keeps calling to me to fix it. It is a neat little engine, but probably underpowered for the weight. Not to mention the factory aluminum rods might not agree with aircraft use. As a motorbike though, they are pretty cool machines......which explains the pile of parts in my shop....
kennyrayandersen
Jun 6, 2011
73
Ft. Worth TX
Old thread, but I thought I would add that my 1963 FIAT 500 has a 2 cylinder engine with both cylinders on one side that that fires ever other rev. It has an [relatively] enormous counter-weight to help smooth it out. It make, on a good day 17.5 HP...
Another in-line twin is the Kawasaki ex-250, which for the life of me don't understand why that isn't being tried in a small aircraft (available now in 300 cc version)
StarJar
Sep 6, 2011
1,723
El Centro, California, USA
There is significant weight difference between 1/2 case and 4 cylinder engine. If that mod done properly, like cutting case and crank, it will save lot of weight....saving list include: approx 1/3 case, 2 cylinder, approx 1/2 crank, one head, two piston, two rod.....I read somewhere that there is some "conversion" that use full case and crank, but that will be odd and inefficient way to do it, only small benefit for weight and power level only 1/2 of original.
The full case 1/2 VWs, also cut the crank, and cam in half.
The advantage is more oil capacity, and heat dissipation, and less cost and work.
The disadvantage is about, 8 lbs* extra weight. ( * that is an educated guestimate)
Doug2233
Jan 10, 2011
48
Sydney, Australia
In this country there was a common range of air compressors found in hire shops for road breaking jack-hammers that used a VW engine with two cylinders on one side running as an engine and the other side cylinder pair used as the air compressor. The compressor side used a special cylinder head with reed valves.
It was a pretty neat arrangement and I recall they ran smoothly with an even firing interval. I have no idea if they were fitted with a special camshaft to enable this configuration.
9,026
The VW engine/air compressor was advertized in the U.S. in the 1970's in the VW auto magazines, but I never saw one.
Dan
Mcmark
Sep 24, 2013
444
Owings, MD
Demello Machine in CA builds counterweighted cranks. Been doing it for a long time. Home Page
A unique look for this old engine. Would fit a lot of airframes cleaner aerodynamically.
Would fit best cylinders down, but that complicates.
Following with great interest.
Mark
