Hi;
Does anyone have diagrams of where the CG of a human is located in the sitting position? I'm doing some balance related work on a Murphy Renegade (altered to look more like a "Little Toot.")
I want to get the seating position close to correct. In my attachment, you can see 2 occupants, and the vertical line is my best guess at where the lift acts in steady level flight. I made the assumption that for each wing, the lift acts at about 25% chord, then accounted for the fact that there are 2 wings, and top one is swept 10 degrees.
The lift line cuts right through the front seater, and presumably, the CG of the entire aircraft would be a few inches in front of the lift. Also notice that the legs of the front guy are more scrunched up then the back seater, and I know this would affect the CG of that person.
My goal is to ensure that overall CG wouldn't change much if I had a light person or a heavier person in the front. So his CG should be close to the airframe's CG, at least in my mind.
So, anyone have any such diagrams?
Thanks, Tom.
Thanks, Tom.
