... "Thjakits, I've got a copy of the Olds conversion plans. Looked really intimidating when I bought them about 30 years ago (is a personal note from Steve worth anything?), but don't look that bad after getting a little building experience." ....
It certainly has historic value!!
This olds - I believe - is also the ancestor of all the british Rover V8s, right?
Considering the omnipresent Chevy LS series and even "more modern" Lexus LS V8s - I wonder how much work it would be to conver one of those to run inverted? Dry-Sump systems are plenty out there - a prop-bearing-plate/front engine mount - for the V8 to bolt on with the fly-wheel side (....a las Paul Lamar's rotary mount!) and you should have quite an engine! optimize the heads and cams for low rpm and you should have quite a 360 competitor!!
Lexus is already all-alu and 300hp out of the car, it get's pumped to around 800 hp regularly, so the structural integrity is there to support 200 or so hp at lower rpm.... - most certainly, though any Lexus or Chevy would need some boost (charger or turbo) to produce 200+ hp at 3000rpm or below....
[I wonder though what happened to the certified version of the Lexus V8, with a TBO of only 300 hrs or so...?]
At the end though, it is a basic question of weight to power ratio....INCL. all ancilliary items!
It's always down to "...does the stuff I take out and replace with something else have more performance or less?"
Cheers all!
Happy New Year!!
thjakits
Wiki says: "
Derivatives
FV2400-2TC
In 1997, the US
Federal Aviation Administration granted production certification for the FV2400-2TC, a
twin-turbocharged airplane powerplant based on the UZ series Lexus engine.
[9] The 360 hp (268 kW; 365 PS) FV2400 was developed in partnership with
Hamilton Standard, which provided the digital engine-control system.
[9] The goal was to produce a four-seat propeller aircraft.
[10]
VT300i
In 1998, a marine derivative of the UZ powerplant was produced for boating applications. The 4.0 L VT300i engine, producing 224 kW; 304 PS (300 hp) at 6000 rpm and 420 N⋅m (310 lb⋅ft) at 4200 rpm, used the same block as the UZ engine on the Lexus SC 400, GS 400, and LS 400."
Here a discussion in ZA - with a few wrong assumptions mixed in:
And here another one:
I seem to remember that back in the late 90's Toyota got an engine FAA approved, IIRC it was the V-8 that was used in the Tundra (with I'm sure a few
www.city-data.com
And a bit about the Lexus V8:
Development of the LS began in 1983 as the F1 project, the code name for a secret flagship sedan. The resulting sedan followed an extended five-year design process at a cost of over US$1 billion, a…
whycars.wordpress.com
SORRY for the departure from Tailwind specifics!!
Cheers all!
