I think it has to be a reflex you build into yourself-- "engine dead--> immediately push stick forward." Otherwise you're probably going to stall, as the upward momentum keeps the plane climbing (and airspeed falling) after the engine quits.
Or the left wing simply tip-stalled and he spun in. Unless the observer actually saw the ailerons move it might be hard to tell.Fritz showed us the right way to handle an engine failure. Here is the wrong way.... http://www.kathrynsreport.com/2018/02/accident-occurred-february-05-2018-near.html
"The airplane then departed. When it was about halfway down the 4,000-ft-long runway, the witness heard the engine lose power. He stated that there was no sputter or sound of a rough-running engine, "the rpm just decelerated." The witness looked up and saw the airplane about 100 ft above the runway. Instead of landing on the remaining runway, the pilot made an "aggressive bank" to the left and the airplane stalled and descended "straight down" toward the ground."
I sure can't make any sense of the GPS log in the report. It looks like the plane never exceeded 24 kts (ground speed?). Winds were 9 kts right down the runway, but still, the plane wouldn't climb at 33 kts airspeed even if someone tried to (for whatever reason). I'm guessing something is wrong with the data or there's a unit conversion issue.Or the left wing simply tip-stalled and he spun in. Unless the observer actually saw the ailerons move it might be hard to tell.
It depends on the airplane and its airspeed. An airplane whose momentum is high relative to its drag has much greater time to change pitch before stalling. (Recall that force is the rate of change of momentum.) An airplane whose airspeed is high relative to its stall speed has much greater time to change pitch before stalling.I think it has to be a reflex you build into yourself-- "engine dead--> immediately push stick forward." Otherwise you're probably going to stall, as the upward momentum keeps the plane climbing (and airspeed falling) after the engine quits.
I always adhered to this. Additionally (subsequent to an article by Richard Collins a lifetime ago), I always used best angle of climb to at least 500 feet.BTW, I was taught not to make any engine power adjustments until at a “safe” altitude, because engine failures were believed to occur more frequently during changes in power settings. Is that still being taught? Is there data to support that supposition?
I think that's frequently a good technique, in general, but it does require a concomitant dedication to act promptly to get the nose down if things get quiet.I always adhered to this. Additionally (subsequent to an article by Richard Collins a lifetime ago), I always used best angle of climb to at least 500 feet.
Doesn't best rate get you to a more survivable altitude quicker and with more stall margin, in case the engine quits and you're slow to push the nose over?I always adhered to this. Additionally (subsequent to an article by Richard Collins a lifetime ago), I always used best angle of climb to at least 500 feet.
From my view, again, it depends on the aircraft. In something like an ultralight, I would rather have altitude and be close to the runway, but in something like my Sportsman, I would rather have airspeed, so my initial climb is at best rate, which is, with TO flaps, about 35 knots above stall.Doesn't best rate get you to a more survivable altitude quicker and with more stall margin, in case the engine quits and you're slow to push the nose over?
There is a solution to that. Check out episode 69 of the Sonex Flight podcast.Also, the wing isn't particularly long...
Agreed, Fritz chose wisely. Even if a return might have been possible, no one can say, but picking a suitable off field site within range is never a wrong decision.Fritz showed us the right way to handle an engine failure. Here is the wrong way.... http://www.kathrynsreport.com/2018/02/accident-occurred-february-05-2018-near.html
I do this too. After rotation for takeoff, I continue to pitch for Vx and then hold that until I am past the trees at the end of the runway and high enough to set up a glide to the fields just beyond the houses and river, then I lower the nose to Vy. No point in holding Vx beyond that because I have to remain below the Class C shelf for about two miles.I always adhered to this. Additionally (subsequent to an article by Richard Collins a lifetime ago), I always used best angle of climb to at least 500 feet.
35 knots! My Hatz stalls at 45 indicated, Vx is 50 or maybe even less, Vy is 55, I normally climb at 60 to be comfortable and cruise at 70. That's the way it is with a draggy biplane.From my view, again, it depends on the aircraft. In something like an ultralight, I would rather have altitude and be close to the runway, but in something like my Sportsman, I would rather have airspeed, so my initial climb is at best rate, which is, with TO flaps, about 35 knots above stall.
It took me quite a few flights before I got accustomed to the airspeeds. I can aggressively rotate and pull full flaps and fly away at around 42 to 45 KIAS. With normal takeoff flaps, I fly off at around 50 to 52, and best RoC is 85 K, flaps retracted. Best angle is around 75 K.35 knots! My Hatz stalls at 45 indicated, Vx is 50 or maybe even less, Vy is 55, I normally climb at 60 to be comfortable and cruise at 70. That's the way it is with a draggy biplane.
Yeah, but I want most altitude in the shortest distance. Personal preference. And I practiced a lot of slow stuff with my best flying buddy. We liked to challenge each other - safely.Doesn't best rate get you to a more survivable altitude quicker and with more stall margin, in case the engine quits and you're slow to push the nose over?
Thanks, interesting. In a nutshell (per memory, might be a bit off):There is a solution to that. Check out episode 69 of the Sonex Flight podcast.
View attachment 94057 View attachment 94058 View attachment 94059
On my recent flight review, the CFI wanted me to switch fuel tanks before takeoff so he could set the fuel timer. I agree with your CFI. I'm a CFI also. I select the fullest tank as part of my pre-flight.I was taught never move the fuel selector at runup or takeoff.
Does the FAA require a full power fuel flow test before first flight?
Not explicitly, but it may be up to the DAR's discretion. I don't recall if my DAR asked about it or not.I was taught never move the fuel selector at runup or takeoff.
