Any Gazaile 2 builder here?
stevetosh
Dec 25, 2010
198
brisbane, Australia
Hi folks,
Anyone here building gazaile 2 here? I received my plans from Serge yesterday and want to to ask some few questions regarding C1, C2,..... Etc. The plans are good but I need heads up on how you guys started.
Cheers
saini flyer
Mar 12, 2010
462
Dallas, TX
Steve, I cant answer your question but have more questions for you:
  1. What engine are you planning on using?
  2. What is the anticipated build time for Gazaile 2?
  3. Is there a possibility of using CNC machining to reduce the build time?
sming
Apr 10, 2019
65
Hi! Yes i'm a wanabe gazaile builder ;) but i can try or forward your question to Serge.
Btw there is a builder forum, you didn't get access?
And there is now a new gazaile 2 forum (I am the admin), more free (some people didn't like the way Serge handled his replies), more modern. I have yet to create the non-french section but go ahead I'm here for the translation.
https://gazaile2.heolite.com
  1. What is the anticipated build time for Gazaile 2?
  2. Is there a possibility of using CNC machining to reduce the build time
Around 2000 to 3000h. Usually 3 to 5 years, depends on builder. Yes cnc can help, a lot of DXF files exist, for the 18mm plywood corners and firewall for exemple, or all the metal parts for the controls (you can buy them lasercut from Serge)
stevetosh
Dec 25, 2010
198
brisbane, Australia
Hi sming,
Good to read from you. Yes Serge need to get something done for non French speaking builders, am going to register on the site now. Catch you there Sming
stevetosh
Dec 25, 2010
198
brisbane, Australia
Hi,
Am not sure of which engine am going to use, but definitely am build g the ultralight version. So probably the Peugeot e vine will be my choice.
