The latest CLAW will not allow departure from controlled flight. An F-35 pilot cant do anthing with the controls which will over -g, stall, spin, or otherwise depart the aircraft. Let that sink in for a minute.
To be fair:
* Meeting the performance requirements for that aircraft (or any modern fighter since the 80s) pretty much mandates a statically-unstable design. Fly-by-wire is therefore a necessity from the beginning.
* Aircraft like the F-35 are intended to be flown right at the limits of achievable performance, while the pilot is very much occupied doing other things like trying not to get shot. The less of the pilot's brain that needs to be occupied trying not to exceed performance limits and remembering which combination of controls to use in this situation vs. that one, the more can be devoted to situational awareness, weapons employment, etc.
Also note that the biggest deal with the F-35 is the sensor integration and networking. It's all designed to give the pilot the best information possible in an easy-to-understand format, to maximize his chances of successfully completing the mission and getting back home. The less of his finite mental processing ability he has to devote to playing sensor integrator and control limiter, the more he has available to do the higher-order stuff.
They don't give a hoot about purity of the mechanics of flight or raw man-over-machine skill. It's all about getting the job done.
This is much the same reason for the increasing prevalence of FBW and advanced glass in airliners and other passenger aircraft. The most feasible means of improving safety for the general public is what's going to get used, and the numbers say that's the solution.
Now, bear in mind that pretty much all of these pilots (commercial and military) are still training in aircraft with direct mechanical/hydraulic controls. I suspect that will continue to be the case for a while longer. Perhaps the training needs some changes, but the basics should be there form the beginning. The trick is probably maintaining those skills over the long term with periodic refreshers.
We are creating a generation of pilots that can ham fist the controls in the pattern without any fear of an aerodynamic stall. Im sure this is going to significantly improve safety, but will these pilots even be able to fly an airplane with direct linkage control architecture? We have enjoyed anti lock brakes on cars for years now, and have learned that maximum shopping = stomp on brake as hard as possible and the car will figure out the rest. Safety improves, yes, but how do these same drivers do when you drop them behind the wheel of a 69 Chevelle on an icy road?
With the car example, at least, it's almost irrelevant. The vast majority of cars on the road today have ABS. We're nearly to the point that anyone driving an older car without ABS, electronic engine controls, etc. is doing so by choice, and therefore will learn how to handle that car. And most likely, a collector car like that isn't going to be driven on an icy road anyway. It's like worrying about people not knowing how to use slide rules and trig tables any more. As long as you can do basic hand arithmetic, even a dirt-cheap calculator can do the complex stuff.
With aircraft it's a little different; the bulk of the GA fleet (and a substantial portion of the airliner and non-fighter military fleet) is still mechanical controls, and that'll remain the case for a long time.
I know we (pilot community) grouse a lot about people who blindly follow a GPS and don't know what to do if it breaks or isn't there... but the common knee-jerk reaction of teaching pilots "paper charts, only paper charts, and nothing but paper charts" and pretending that GPS doesn't exist isn't going to solve that problem--it mistakes the messenger for the message. I'd argue the better solution in this case is to teach
responsible GPS usage, with the paper navigation as fundamentals and as a fallback. Emphasize situational awareness, planning, and being able to recognize bad data or a failure with sanity checks (after all, that's the important part... right?). Fussing over the paper chart minutae of calculating ground speeds and course corrections "on the fly" with an E6B doesn't buy you much. There are more important lessons to be learned.
