Another dumb noob question...
Discussion in 'Workshop Tips and Secrets / Tools' started by Thunderchook, Dec 22, 2016.
  1. Dec 22, 2016 #1
    Thunderchook
    Thunderchook
    Thunderchook
    Jul 27, 2016
    246
    36
    Queensland, Australia
    Has anyone tried coating a particularly critical load-bearing structure (like, say, a wing spar) with this Line-X coating?
    https://youtu.be/30Q4HK7wcJE
    Weight penalty?
    Benefit/deficit ratio?
    Apologies if this has been asked/discussed before.
  2. Dec 22, 2016 #2
    Winginit
    Winginit
    Winginit
    Jun 13, 2016
    811
    242
    x
    It's been suggested that fuel tanks might benefit from an external coating of LineX.
  3. Dec 22, 2016 #3
    Thunderchook
    Thunderchook
    Thunderchook
    Jul 27, 2016
    246
    36
    Just the fuel tanks?
    Nothing else?
  4. Dec 22, 2016 #4
    N8053H
    N8053H
    N8053H
    Jan 31, 2013
    2,523
    442
    If I paint my car with this will it then be a tank? Might have to try this...lol
  5. Dec 22, 2016 #5
    N8053H
    N8053H
    N8053H
    Jan 31, 2013
    2,523
    442
    I see they tried this. They made one mistake by only coating one side of the car panels. I would coat all sides by taking the car apart and then putting it back together.
    [video=youtube;COXW3Rf3pcY]https://www.youtube.com/watch?v=COXW3Rf3pcY[/video]
  6. Dec 22, 2016 #6
    Battler Britton
    Battler Britton
    Battler Britton
    Nov 14, 2015
    511
    353
    Montpellier,LFNG (Candillargues)
    nice..but what about aerodynamic, and ....weight!!
  7. Dec 22, 2016 #7
    Thunderchook
    Thunderchook
    Thunderchook
    Jul 27, 2016
    246
    36
    .... which is what I basically postulated in the OP.
    The videos basically show plastic cups with a coating of 1-2mm.
    Has anyone done the numbers?
    My thinking is that you could use a very light material (e.g. Styrofoam) and coat it with this tuff.
    it would be good if someone could give it a try and then apply loads to test the potential.
  8. Dec 22, 2016 #8
    13,166
    5,079
    There you go...I've never trusted the idea of foam-only wing ribs, but coat them or make them out of this stuff and...
  9. Dec 22, 2016 #9
    Riggerrob
    Riggerrob
    Riggerrob
    Sep 9, 2014
    1,254
    367
    Canada
    LineEx would be most valuable to bush pilots, cargo pilots and crop dusters who routinely land on gravel strips. LineEx could protect high-wear areas like door frames and cargo floors. LineEx could also reduce rock chip damage to the undersides.
  10. Dec 22, 2016 #10
    13,166
    5,079
    Never break another prop! :gig:
  11. Dec 22, 2016 #11
    D Hillberg
    D Hillberg
    D Hillberg
    Nov 24, 2010
    1,182
    431
    very low low low earth orbit
    We used it for edge trim on the 214 huey seat and thin plywood floor liners - it lasts and lasts , thinking on using it for fuel system (aluminum & nylon cloth tanks) great stuff
  12. Dec 22, 2016 #12
    13,166
    5,079
    Looks like amazing stuff, but...
    Is it fuel-proof and alcohol-proof? What is the longevity of the stuff? Does it harden or get brittle with age?
    In regard to using it on a spar, the spar should already be designed to handle all normal loads. If you need this stuff to supplement the spar, then you will need to know the materials properties before you can properly calculate its application and effect. Once on, how do you inspect the spar or do repairs on the spar?
  13. Dec 23, 2016 #13
    Kevin N
    Kevin N
    Kevin N
    Jan 23, 2015
    819
    466
    Your Moms basement
    I know guys are spraying that stuff on wore out alaskan bush wheels. Anything to get more life out of tires that cost 4 grand.
