Another cross country thread
davidb
Jun 3, 2008
1,731
Vacaville, CA
On or about February 10th, I’ll be ferrying my airplane back from Florida to California. Considering winds, weather and my limited string of available days, I may have to leave it somewhere along the way. Worse case, I’d leave it south of Dallas. Better, I’d leave it near El Paso. Best case, I’d make it as far as Phoenix. It could be weeks before I could then continue the ferry operation.
I have made this journey fro and to before with rather good fortune so I’m probably due for some bad luck this time. I’m mainly posting as a reach out for transient hanger space ideas. Right now I’m looking at the three cities above because I could easily get home and back to those areas commercially. Anybody here live near those areas with hanger availability knowledge?
I will plan and make calls as the journey progresses but I figured it would be good to pose this to the forum. Below is a screen shot of a likely route. Figuring an 85 KIAS cruise, I’m faced with over 30 hours of flying and seven or maybe less days of opportunity.
blane.c
Jun 27, 2015
4,842
capital district NY
My son goes to the Arizona flying circus, say's it's a blast. On the internet flyer it says; For more info please call Mo Sheldon at 602-692-7995.
davidb
Jun 3, 2008
1,731
Vacaville, CA
Pun noted, haha. A mix of guns, cannons, pyrotechnics, explosives, flying machines and courage altering substances; what could go wrong? Seriously, it does sound like fun but I wonder if there is some level of security and safety in place.
jedi
Aug 8, 2009
2,470
Wow, that looks like fun and the dates align with my ferry timeline. Do you have firsthand knowledge of this airfield and the event? It says they have an open hanger but not sure what that means. My concern would be safety and security, both during the event and after if I were to leave the airplane there.
I am familar with Mo and the event. Sounds like you are a fellow airline employee with transportation home. Text me for more info. 425 495 7946.
jedi
Aug 8, 2009
2,470
"guns, cannons, pyrotechnics, explosives," Seriously, how much security do you need. I can assist with camping privileges and provide transportation to PHX if needed in exchange for aircraft storage and possible delivery to your destination.
davidb
Jun 3, 2008
1,731
Vacaville, CA
I started the journey yesterday and made good progress a with 20 knot tailwinds. Spent the night in Nacogdoches. That was a bit of luck and fortunate timing to make it that far. Alas, luck has run out. I only made it one leg to Palestine, TX today and it looks like I’ll be here until Tuesday morning. Low IFR followed by high surface winds will keep me grounded until then. It’s a bit of a complicated weather pattern going on across the Southwest.
I was able to verify that the automated weather observations look straight up ;)
Jul 29, 2005
14,576
Moderator Note: Moved this thread from Hangar Flying to Upcoming Events and Trip Reports, as it seems a better fit there. Left a 2-week expiring redirect in the original location.
Have a great trip, David!
davidb
Jun 3, 2008
1,731
Vacaville, CA
Thanks. As predicted, no progress today. IFR conditions will move east of me through the night and I’m shooting for a sunrise departure tomorrow. With the frontal passage I’m faced with strong headwinds aloft and surface winds possibly beyond my limits. I’ll have to pick and choose fuel stops with care as all stations will see shifting direction and velocity. Making it past Texas tomorrow will require superior skill and cunning. I have neither so I’l need luck and ForeFlight to get me through.
blane.c
Jun 27, 2015
4,842
capital district NY
Good luck then
davidb
Jun 3, 2008
1,731
Vacaville, CA
Good luck then
I had some of that today and turned some bad luck into good progress. Ended up doing three, three hour legs. The last one was planned as a one hour leg to Carlsbad but the surface winds blew up a half hour out. Started fingering the ForeFlight and decided to push on to El Paso which had calm winds and trustworthy indications it would stay that way. It did. This is a view I wasn’t supposed to have today:
Tomorrow I hope to reach Blythe but the surface winds are forecast to blow up before I can get there. A bit more luck will be welcomed.
9,273
If you need any support, rescue, nuts and bolts, etc. as you pass by the Los Angeles area I am located at Whiteman Airport KWHP.
eight one eight six three four nine seven six two
We're having rain and overcast now in the LA basin, I would suggest you pass around the eastern area through Palm Springs, Hesperia, Apple Valley, Lancaster WJF, etc. Be prepared to wait in Lancaster, your next stop after that is the Bakersfield area which may be solid overcast. When it gets overcast in that area it is overcast through the whole Central Valley and you could be on top of an endless layer of solid cloud down to 10 feet AGL.
Also, if it is cloudy and significantly windy in the Mojave desert, I would stay out of Mojave and Tehachapi. They get wave rotors and very unpleasant turbulence in the western Mojave Desert when frontal movement goes through there in winter time.
cdlwingnut
May 25, 2015
535
Iowa
I may have been mentioned and i missed it, but what type of aircraft are you flying this trip in?
davidb
Jun 3, 2008
1,731
Vacaville, CA
Yup!
I got a sunrise start out of El Paso this morning and made it to Blythe at 1pm. I was pushing pretty hard to make that happen. I probably had the opportunity to make Apple Valley but my body and mind weren’t up for it. I certainly wasn’t capable of handling challenges and could not think straight enough to analyze the weather moving in. Anyway, looks like I’ll be stuck in Blythe for a couple of days.
13,314
I’m enjoying following your progress.
Since I retired, cross countries are more enjoyable. I now think of weather delays as an opportunity to explore another airport / town / restaurant etc.
davidb
Jun 3, 2008
1,731
Vacaville, CA
It’s a SeaRey SLSA with the Rotax 914 (turbo). It’ll climb and go high but it flies at LSA speeds. Four hours of fuel. Like most LSAs, headwinds hurt and swirling surface winds tax one’s reflexes. I flight plan for 100 mph TAS.
Edit add: here’s pictures of what wind does.9ED2E330-A652-4EB7-8C0C-4F37ED9829D3.jpg4329E573-BF8F-4492-9FBA-EFCD1F1D5E75.jpg
That’s over a 90 mph ground speed swing. I change altitude to find the best compromise of TAS, wind, and turbulence. So far I haven’t had to accept less than 80 mph ground speed.
Toobuilder
Jan 19, 2010
5,176
Mojave, Ca
I've been stuck in Blythe for a few hours.
...was the longest week of my life!
9,273
Chiriaco Summit Airport is a worthwhile stop west of Blythe. The General Patton Museum is there right next to the airport, and a gas station right at the runway if your airplane can use car gas.
Stay to the north of Banning Pass if the wind is blowing westerly through there, really big headwinds AND sinking air downwind of the pass. Banning Pass is a venturi and amplifies the general westerly wind speed by 50%. My suggestion is to stay on I-10 until you are over the farm fields and "civilization" at the eastern end of Coachella Valley, then skirt the northern edge of the Coachella Valley and veer right through the lowest hills toward Yucca Valley airport.
In westerly winds (common), stay as far downwind of Mt. San Gorgonio (11,499 ft.) as practicable on your way towards Apple Valley. Basically I'd suggest taking a curved path to follow Highway 247 / Old Woman Springs Rd. instead of getting too close to the mountain.
After you leave Apple Valley and go through Victorville KVCV, make sure to squawk 1200 and let VCV know you are proceeding westbound. Whatever you do, avoid landing or loitering at either Gray Butte airport or El Mirage Adelanto airport. There's stuff down there you ain't supposed to see, and some nice folks down there at General Atomics will likely be watching you as you pass through.
If you happen to have reason to curve around to the north of Apple Valley a few miles, and you happen to see the town of Helendale, you might notice a triangular airport with a long tapered runway looking strip next to it. You really don't want to drop in, ain't nothin' but rattlesnakes there.
Krey airport is no longer being used, and there's meth labs and desert zombie type people around that area. El Mirage dry lake is a lot of fun to visit under other circumstances, but due to recent rain it is not a dry lake at this point, you'd be landing in some really nasty wet mud.
If you need a place to land in that area go to Brian Ranch (shown as Brian pvt on the chart), it is an active ultralight and LSA airfield. There are people there who are familiar with LSA type aircraft and might be able to offer help.
Lancaster / Fox Field WJF is a good place to get lunch, but it does get windy most of the time. Don't be surprised to see 25-35 kt winds.
If you see lenticular clouds (long smooth knife blades at high altitude) to the north and west of Fox Field, and it's cold & windy form the northwest, you might think twice about proceeding further west or north on that day... it's going to be an unpleasant and memorable ride.
If you happen to be headed northwest from Fox Field and are flying over a large area that is packed with hundreds of windmills, you might see an airport and some hangar buildings that is not marked on the chart, right where the little word "Antennas" is shown on the chart. It's not an airport and you are not welcome there at Northrop's White Oak RCS range either :)
Once you get over the hills west of Lancaster and into the Bakersfield area, assuming that you have VFR conditionss in Bakersfield, it will be a relatively easy flight from there back home.
http://www.otherhand.org/home-page/area-51-and-other-strange-places/bluefire-main/bluefire/radar-ranges-of-the-mojave/northrup-rcs-facility-at-tejon/
http://www.thedrive.com/the-war-zone/15746/lockheeds-helendale-radar-signature-test-range-looks-right-out-of-science-fiction
http://www.otherhand.org/home-page/area-51-and-other-strange-places/bluefire-main/bluefire/radar-ranges-of-the-mojave/mcdonnell-douglas-gray-butte-rcs-facility/
https://en.wikipedia.org/wiki/El_Mirage_Field
davidb
Jun 3, 2008
1,731
Vacaville, CA
If you need any support...
I’m pretty much stuck in Blythe until Friday or beyond. It’s too early to guess but the LA basin route might be better than the Lancaster route by the weekend. KWHP looks like a good location to make the jump to Bakersfield and beyond so I’ll look for you if I go that way.
Edit: I didn’t see your post above until I hit send. If I go the Lancaster route I’d top off at KTNP. From there I can overfly Lancaster nonstop to Bakersfield if I have less than 20 knots of headwinds. If I go the basin route I can make Redlands for fuel.
