Anderson KingFisher Float Planes
Airwolf1
Mar 5, 2011
10
Clarksburg, West Virginia USA
Manion - I have had the plans, boat hull frames, and water rudder parts for a number of years for my
Anderson Kingfisher. Now retired, its time to build it. I am looking for a set of Piper tripacer wings to
use and a Lycoming 0320A2A (150 hp). Do you still have your Kingfisher?
craig saxon
Sep 26, 2010
549
Canberra, ACT, Australia
Could you use the wag aero plans to build the wings? There is a yahoo group but it's not very active.
Anderson-Kingfisher : Anderson-Kingfisher
Craig
Airwolf1
Mar 5, 2011
10
Craig,
I suppose you could. The plans do not give a specific airfoil, but I did see a website detailing the type airfoil used. I just
did a search with the airplane name. WagAero wings are similar to factory built Piper Cub wings. I am intending use of
the Piper Tripacer wing as it is all metal and stronger.
craig saxon
Sep 26, 2010
549
I'm pretty sure, although someone will correct me if I'm wrong, Wag used to offer plans for a pacer clone. If not, they do supply parts for most of the high wing pipers, including I think, pma'd metal spars, fuel tanks and ribs. Probably worth contacting them and sounding them out. I think Wicks offer parts too.
Craig
Nate
May 8, 2011
12
Bethel, Maine / USA
I have a set of Pacer wings, looking to sell. They're in great shape, ready to be recovered. Going with the Alaskan mods, so I wont need the wings I've got.
puddles
Jul 15, 2011
1
New Zealand
Are there other owners in the forum or any others building any, would enjoy hearing from you.
Hi manion, I have a kingfisher, It had a weel down landing 10 yaers ago. I have rebuilt it over the larst 4 yaers. Im just learing ta drive a computer. so will try ta get a pickture up in the next day or so! cheers. puddles
Ken Potter
Jul 20, 2011
4
Lanark, Ontario, Canada
Hello,
I am in the process of purchasing a Kingfisher project here in Eastern Ontario, Canada. I've had a set of plans for many years but decided to get a head start by acquiring one which has many usable parts. I look forward to intereacting with other owners and builders on this site.
Cheers,
Ken Potter
Lanark, Ontario
john55555
Aug 9, 2011
1
Scotland
2 x Kingfisher restorations just starting in the Orkney Islands in Scotland, I will post updates.
O236 now rebuilt and Polyfibre covering about to be applied. It will be ready for flight in March next year.
Heavy Iron
Aug 27, 2011
12
Dundalk, Ontario / Canada
Hi Ken,
Are you buying the one that was built out west but has never flown? I went to look at it early in July but it needed far more work than I had time for. I kept looking and found a Volmer Sportsman project that I should be able to get flying before the snow hits us again.
Good luck,
Ron
Ken Potter
Jul 20, 2011
4
Hi Ron,
Yes I bought it but for very little money. In fact, the Piper Cub wings were worth more than I paid for the entire project. It was not as advertized and in fact I believe that it was built in the US and somehow re-registered in Canada. It appears to be mid 1970's vintage. I'm looking for for a new fuselage and have located one nearby in Ottawa. And btw, the Volmer Sportsman would have been my second choice for an amphib "flying boat"
Cheers
Ken
Heavy Iron
Aug 27, 2011
12
Hi Ken,
Certainly it had a lot of good parts included and will give you a great start especially if you can find a well built fuselage to go with it. I got the Volmer trailered home from Saskatchewan on Labour Day weekend so now the fun (and the work!) begins. When it's flying I will eventually be coming over to visit your neck of the woods as my brother has an RV-8 hangared in Smiths Falls.
Ron
C-90 Cub
Jan 23, 2013
3
Alexandria KY
I am restoring an Anderson Kingfisher.
I also have another project that hasn't flown that has the fuselage built 90% of all the metal fittings including all the tailfeathers and a set of plans to go with it. Has a little hanger rash but a well built airplane. If anyone is interested let me know.
Steve Trutschel
strutschel@live.com
Ken Potter
Jul 20, 2011
4
Hi, the new fuselage is very high quality as are the tail feathers that came with it. I started on rigging the vertical and horizontal control surfaces last winter. Looking at eliminating as much weight as possible from the plane. The basic plane I have has a CoA (it is the one built by Conrad Steward, taxi tested but never flown). I'd like to go with the original 0-290d, but if I can lighten it up enough will look at the 0-320. Between the two planes I have enough parts for a new one with some to spare, probably for sale. This will probably include an entire set of fuselage metal hardware.... Cheers, Ken
skydad
Aug 9, 2013
19
Covington, Louisiana/USA
I built a Kingfisher and sold plans for it for several years after Earl Anderson decided that his hearing had gotten so bad he couild no longer communicate with folks. Don't use the Tri-Pacer wings. It needs more wing than that. There were drawings in the plans that Earl had and that I sold that were for a wood spar & rib wing. When I built mine, I bought a set of metal spar blanks from Univair. I had several old Tri-Pacer wings that I used the ribs & hardware out of to build up my wings using the spar blanks. My plane has a 150 Lycoming with a Sensenich 74DM52 prop. The engine was mounted 2" higher than the plans call for because of the longer prop. I Used an 18 gallon Piper gas tank in the right wing along with the nose tank which was 22 gallons. I built a door on both sides and used Cessna 150 seats with the extra stuff on side of the seat frame removed. I made a wooden base and mounted seat tracks on it so my seats were adjustable, otherwise, it is about like trying to get in the front seat of a J-3 Cub. Empty weight is 1125 lbs and I used 1800 lbs for gross. I am 6'2"+ weigh close to 300 lbs and with a full nose tank and a 160 lb. passenger it would get off the water. Cruise - 90 mph. I sold the design rights & master drawings to a guy in Kentucky, I think it was, and they have been sold several times. The last I heard, someone in Maine was selling plans for it. It is a very forgiving good flying airplane, but you must keep it light. Copy the J-3 rudder outline to build the rudder for it. That extra balance area over the fin makes it fly like its on tracks, Otherwise, in bumpy air, it will tend to yaw and not straighten up unless you straighten it up. I underrstand the Volmer Sportsman did this also.
hfbarber
Jul 26, 2015
1
Anchorage, Alaska
I am parting out a Kingfisher (350 hours on plane) and have landing gear, tip floats, nose tank, tail feathers (balanced type), adjustable seats, etc.
