ANC-18 - Design of Wood Aircraft Structures
Discussion in 'Wood Construction' started by Jman, Nov 20, 2010.
  1. Nov 20, 2010 #1
    Jman
    Jman
    Jman
    Site Developer
    Oct 22, 2002
    1,881
    58
    Pacific NW, USA!
  2. Nov 20, 2010 #2
    rheuschele
    rheuschele
    rheuschele
    Jan 13, 2010
    533
    41
    Chicago Il. USA.
    Thanks, I had this in my computer years ago and had a virus that took several documents including this one.
  3. Nov 20, 2010 #3
    Jman
    Jman
    Jman
    Site Developer
    Oct 22, 2002
    1,881
    58
    Pacific NW, USA!
    No Problem. It was Autodidact's idea and a good one. Within two months we are going to have a digital library started here on HBA. Some pubs will be downloadable and some as web links to where you can read or download them.
    Blissment likes this.
  4. Jun 19, 2011 #4
    Woodenwings
    Woodenwings
    Woodenwings
    Aug 2, 2006
    164
    5
    Toronto
    Oooh! that wood be grand!
    I have a PDF collection also!
  5. Jun 19, 2011 #5
    4trade
    4trade
    4trade
    Nov 1, 2010
    527
    71
    Lahti/Finland
  6. Dec 16, 2011 #6
    SHIPCHIEF
    SHIPCHIEF
    SHIPCHIEF
    Jan 9, 2011
    57
    3
    Great Northwet
    OUCH!!
    I just read the part pertaining to plywood covered 2 spar shell wings....my head hurts!
    If I read that correctly, the admission of difficulty getting good calculations for loads require the designer to gain considerable experience before reliable structures and records thereof can be obtained!!
    That sounds like building wings and testing to distruction, measure and repeat, & again & again....
    This is not comforting. I've been planning to build another plane after completing my RV-8. This plane being a steel tube fuse, wood wing RV-8 type tandem low wing monoplane. Think Golden Age Classic.
    This kind of wing must have typically been imperically designed in a series by an individual, like an Al Mooney or the team that designed the Lockheed Vega.
  7. Mar 14, 2012 #7
    Dingplast
    Dingplast
    Dingplast
    Mar 13, 2012
    1
    0
    Hailey, Idaho
    I am building my second wood wing. The first project was an acro monoplane and the wing was built with Jon Staudacher. This project is a small STOL strut plane for the Idaho backcountry. Using Marske's template I have calculated the spar caps (spruce) and Graphlite rods. The issue is the spar web for the I beam spar. There will be 4 caps with the rods set in and glued to both sides of the web, top and bottom. Using Tom Rhodes approach I calculate the shear to be 470 lb/sq inch. Is there any data on shear values of modern plywood? The seller LL Johnson can't tell me. I have looked at ANC-18 and half inch Sapele and probably 3/8 Birch are more than adequate. I will use 45 degree and scarf them up. I am looking for test data. I can make samples and run tests if I have to.
    Dingplast
  8. Jul 6, 2012 #8
    larr
    larr
    larr
    Apr 25, 2012
    157
    44
    markham, ontario, canada
  9. Aug 15, 2012 #9
    Catocala
    Catocala
    Catocala
    Dec 29, 2010
    8
    0
    Clermont de l'Oise
    Hi everybody!
    Many thanks to Jman and 4trade for their links to these excellent documents. I don't know how things are running in US regarding wood and fabric ultralights, but here in France, this kind of construction appears rather rare, with some exception. Have a look here:
    http://fms7259.e-monsite.com/
    That web site, which is written both in English and French, is extremely detailed in a very innovative way. The author reports all the problems and difficulties he faces and the solutions he found. Furthermore, his approach is extremely traditional and simple, oriented to the best trade-off between safety and cost. The ULM under construction is very affordable. It's a must see!+
    Enjoy your respective projects. Best regards!
    Catocala
  10. Sep 27, 2012 #10
    Atomic.Sheep
    Atomic.Sheep
    Atomic.Sheep
    Sep 27, 2012
    4
    0
    Melbourne, Australia
    Trying to find this digital library, can't seem to find it?
  11. Feb 8, 2013 #11
    fly_boy_bc
    fly_boy_bc
    fly_boy_bc
    Aug 20, 2008
    236
    24
    Agssiz BC
    I can not find it eiher and the OP was a year and a half ago!Mod?
  12. Feb 8, 2013 #12
    13,166
    5,078
    Which one (link) are you trying to find?
  13. Feb 9, 2013 #13
    craig saxon
    craig saxon
    craig saxon
    Sep 26, 2010
    549
    32
    Canberra, ACT, Australia
    I think they are talking about the one Jake mentioned in Post 3. It would seem a vast undertaking on what is mostly volunteer effort. Juct look at the work that Jarno has put together in the 'Composite' sticky here: https://www.homebuiltairplanes.com/forums/composites/8888-read-first-composites-faq.html
    As with everything worthwhile, these things take time and resources that are difficult to find and or expensive.
    Just my 2 cents worth.
  14. Mar 30, 2019 #14
    Tantrum1
    Tantrum1
    Tantrum1
    Jul 8, 2016
    155
    403
    Saint John, NB Canada
    :(:(:(:(:(:(:(:(:( The links not working!!! I'm away for work and thought I would stop in here to have some extra reading material and brush up on a few topics for some of the up coming processes I need to do on my wing. Anybody have a working PDF link?
  15. Mar 31, 2019 #15
    Marc W
    Marc W
    Marc W
    Apr 1, 2017
    336
    257
    Colorado
    pictsidhe and blane.c like this.
  16. Mar 31, 2019 #16
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    3,786
    676
    capital district NY
  17. Apr 24, 2019 #17
    Nobin
    Nobin
    Nobin
    Jul 10, 2013
    0
    Tavares,Paraiba,Brazil
    There is no file in this link
  18. Apr 24, 2019 #18
    Nobin
    Nobin
    Nobin
    Jul 10, 2013
    0
  19. Apr 24, 2019 #19
    akwrencher
    akwrencher
    akwrencher
    Oct 16, 2012
    1,128
    416
    Gustavus, AK
    Try post 15, works for me.
  20. May 13, 2019 #20
    sawmillpatrick
    sawmillpatrick
    sawmillpatrick
    Sep 9, 2014
    19
    16
    Kansas City, MO
    Alternative wood to Sitka spruce
    Rough sawn aircraft grade lumber non-certified for sale. All tight grained and straight!
    www.woodenaviation.com
    1" x 4" x 8' $28.00
    1" x 2" x 8' $15.00
