Aluminum Tube & Gusset Airbike / Legal Eagle / Parasol Thread
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by Victor Bravo, Oct 8, 2019.
  1. Oct 15, 2019 #221
    plncraze
    plncraze
    plncraze
    May 12, 2006
    1,663
    358
    I saw that Monocoupe in the Smirhsonian! Udvar-Hazy.
    I figured peeling would be critical on the edges and shear towards the middle.
  2. Oct 16, 2019 #222
    6,406
    5,190
    That may be true to whatever degree, I'm not sure. But the joint should be designed such that the holes in the base metal get "opened up" or "oval'ed" before the rivets break.
  3. Oct 16, 2019 #223
    pwood66889
    pwood66889
    pwood66889
    Feb 10, 2007
    1,490
    162
    Sopchoppy, Florida, USA
    Interesting discussion. Especially VB's comment on the unzipping rivets! Do have a copy of a Graham Lee planset (somewhere...), and they are worth it for his building methods. I'll have to see if I can find the information on the air frame design with a pentagon in front and a triangle behind where the pilot fits. Thanks guys!
  4. Oct 16, 2019 #224
    6,406
    5,190
  5. Oct 16, 2019 #225
    3,961
    1,165
    one calculates all of the above....bearing of the various parts, shear of the fasteners. some rivets and holes are under more stress than others based on the distance from the centroid of the pattern and moment of the load to that centroid. See post #188. Obviously you want your loads for each hole to be less than shear of the fastener or bearing failure of either of your joined parts. Knowing the loads on the joint and loading of the aircraft is critical. (I do not have formal training in "Aircraft Stress Analysis") There are also issues of cycle fatigue, and safety factor as regards how close to yield of the material you want to design for. ....it gets pretty complicated which is why "Aircraft Stress Analysis" is a specialty.
  6. Oct 16, 2019 #226
    6,406
    5,190
    'pastie, you are correct, which is exactly why I entrust those types of calculations to an old gray haired retired engineer who has forgotten more about structures and stresses than the instructors at today's engineering schools will ever learn :) What I regurgitated about bearing and shear failures was nothing more than a few of the microscopic flakes of knowledge that fell off the bottoms of this guy's shoes as he walked through my hangar, which I desperately chopped up and snorted hoping to learn something.
    ScaleBirdsScott, Mcmark and Vigilant1 like this.
  7. Oct 16, 2019 #227
    mullacharjak
    mullacharjak
    mullacharjak
    Nov 5, 2010
    117
    29
    Peshawar Pakistan
    Tube and Gusset was used on hovey/Volmer jensen designs before any other.Some one can correct me if I am wrong.
    A two seat T&G Hovey Beta Biird would be great.
  8. Oct 16, 2019 #228
    Mcmark
    Mcmark
    Mcmark
    Sep 24, 2013
    283
    139
    Owings, MD
    Dangit VB, warn us a lil. Almost ruined another keyboard with coffee!!!
    ScaleBirdsScott likes this.
  9. Oct 16, 2019 #229
    ScaleBirdsPaul
    ScaleBirdsPaul
    ScaleBirdsPaul
    Jul 6, 2015
    36
    17
    Connecticut
    Chris Heintz’s book “Flying on your own Wings” has an excellent discussion on loading of multiple fasteners in a line. He provides safety factors to account for the stress “flow” ( not to be confused with shear flow) around varying numbers and sizes of fasteners in a line. This should account for “unzipping” of the rivet pattern.
  10. Oct 16, 2019 #230
    JohnB
    JohnB
    JohnB
    Aug 18, 2019
    29
    28
    "unzipping" brought back memories of watching Molt Taylor do a drop test on the Imp about 45 yrs ago. a line of driven rivets exploded with rivet heads zipping all around.
    Molt unfazed said "well, gotta do a little more work there I think"
  11. Oct 16, 2019 #231
    Bill-Higdon
    Bill-Higdon
    Bill-Higdon
    Feb 7, 2011
    474
    145
    Salem, Oregon, USA
    Some of Hovey's are T&G some like the Whingding & Beta Bird weren't.
  12. Oct 17, 2019 #232
    bifft
    bifft
    bifft
    Apr 17, 2011
    245
    90
    Utah
    I found myself wondering about the weight of a aluminum tube and gusset vs. 4130 tube frame. So as an exercise I decided to try to design a very simple truss as an example. This is a possible one side of a tail boom for my aerobatic part 103 thoughts. I thought I'd show my work as I am a software engineer if anything. Hopefully some of our more knowledgeable posters can point out my mistakes.
    I estimate a 6 G pullup at a VNE of 150 kts requires ~250 lbs downforce on the tail. For a four longeron tail boom, split it into two sides. Assume the 250 lbs downforce is split equally between these two sides for a 125 lbs downforce. Have the tail boom be twelve feet long. Use square 2ftx2ft truss bays because it makes the math simpler.
    [​IMG]
    As this is for an aerobatic plane assume the load could be equally positive or negative. So any tension member in the positive loading would be a compression member in the negative loading. To size the tubes, use the lightest tube such that 80% of the pinned Euler buckling load is at least 150% of the calculated load. See spreadsheet for my tube sizing calcs.
    Using 4130 tube
    longerons 3/4 x 0.028 - 5.2 lbs
    verticals 7/16x 0.028 - 1.7 lbs
    diagonals 5/8 x 0.028 - 3.0 lbs
    total 9.9 lbs
    On the aluminum I used my tension strip idea from a previous post instead of a diagonal tube, since nobody said it was a terrible idea.
    Aluminum tube and gusset
    Longerons 1 x 0.035 - 3.1 lbs
    Verticals 1/2x 0.035 - 0.9 lbs
    Diagonals 2x3/4x0.020 0.4 lbs
    total 4.4 lbs
    I'm not sure how to design the gussets (still studying) but unless there are five pounds of gussets and rivets the aluminum tube comes out lighter. Either could be lightened by stepping the longeron sizes down as you go back, a preliminary look at a warren truss made the 4130 version 1 lb lighter. Another lightening option is to make the bays shorter toward the front where the tail has more leverage and longer toward the back where the forces are lighter allowing a smaller longeron.
  13. Oct 17, 2019 #233
    11,916
    3,413
    For apples to apples what would be the weight gain if you used tubes instead of straps. I think before someone mentioned the Fokker fuselages. The cells are steel tube but used cable for the cross bracing of each cell.
  14. Oct 17, 2019 #234
    6,406
    5,190
    Here's an interesting random thought... If we make a tube and gusset fuselage, and we just added one small extended "tang" to the design of each of the gussets where it needed to be, we might be able to use the gussets as the anchor points for a cable braced truss. I believe the cable braced method is accepted as the lightest possible way to make a truss fuselage.
    Additionally I understand there are synthetic fibers that have the right properties for use in a trust (whatever the correct amount of stretch/spring/strain is). So if the two "cables" in each bay (now light weight synthetic fibers) are lighter than a single diagonal aluminum tube... it might be a reasonably innovative and greatly simplified way to build an E-AB truss, reducing the number of fittings and parts count far below the old classic method.
    The key to this will likely be some better or lighter method of tensioning the cables instead of a classic turnbuckle. A nut system at the attach point on the gusset anchor, or a small bracket riveted to the gusset that you can tighten a nut against.
    Don't know about the cost, but a piece of the 1/16" round Graphlite carbon rod would make a good low-stretch "cable" brace, with a threaded fitting bonded and/or swaged on to the ends.
  15. Oct 17, 2019 #235
    6,539
    2,459
    Might as well go way down this particular rabbit hole? :rolleyes:
    https://en.wikipedia.org/wiki/Tensegrity
    FritzW and proppastie like this.
  16. Oct 17, 2019 #236
    4,240
    1,973
    Those wires will be at resonance with something. Does anyone know about the fatigue properties of these rods if they are free to vibrate? There might also be a corrosion challenge where the CF meets metal.
    There are other fibers that are stronger in tension, but creep is also something to think about.
    Most of the fibers have rates of thermal expansion different from AL, so that would need to be considered.
    I'd miss the compressive strength of the cross members during some unexpected loading scenarios (don't say "crash", it brings out the chorus). That would be alleviated if tension wires went both directions.
    An interesting idea, as long as it works and the dang wires don't have to be retensioned all the time.
  17. Oct 17, 2019 #237
    6,406
    5,190
    Yes, I was referring to bi-directional cross-bracing with all "wires" loaded in tension.
    I imagine a 3 inch long piece of small steel tubing with moderate wall thickness. The outside of the tube is threaded for an 8-32 or 10-32 nut. The inside of the tube is .020 larger than the OD of the carbon rod. The rod is bonded into the tube with the correct epoxy adhesive, JB weld, cab-o-sil, cotton flox and Safe-T-Poxy, whatever is appropriate.
    So the carbon rod does not ever contact the aluminum gusset... the steel end fitting (with CR primer or cad plating) contacts the aluminum gusset or bracket riveted to the gusset.
  18. Oct 17, 2019 #238
    ScaleBirdsScott
    ScaleBirdsScott
    ScaleBirdsScott
    Feb 10, 2015
    1,099
    707
    Uncasville, CT
    That seems like way more work than cutting a tube and drilling a few holes.
    If the goal is minimal weight, and it's a 25% reduction, and the goal doesn't care about cost or simplicity then maybe there's a there there.
    But if the goal is simplicity there's nothing simple to my mind about having to frabricate many pairs of tensioned tube/rod things and ensure they're all sound and so on, in addition to making the normal step ladder frame anyway. Two totally different processes.
    Cut tube, drill hole, rivet, is all quite uniform and simple. There's no making sure the tension is set perfectly, or whether the epoxy joint will hold or whatever.
    From a kit maker perspective it sounds like a bad time.
    From a kit customer/assembler perspective it sounds like a bad time.
    There's a reason everyone left tensioned frames far behind and went to structural trusses. I'm going to guess because it's more uniform to make and more predictable to maintain.
    Again not that i doubt the method works and I even kindof like the idea of using some kind of synthetic fiber cable with some kind of tensioning system to lace up a light but strong frame for a WWI replica. But that's straying off the topic.
  19. Oct 17, 2019 #239
    6,406
    5,190
    Agreed, simplicity favors the all-tube method. My big idea was that maybe the gusset itself could become an anchor for the wire braced structure without adding extra parts, but there would still be extra parts.
  20. Oct 17, 2019 #240
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,747
    3,358
    Las Cruces, NM
    I chased the "airplane in a suit case" rabbit down that hole and was lucky to come out sane(ish)...:confused:
    I have to see it stereo to understand it...
    Idea #2 looked great until I realized it wouldn't work.
