Aluminum Dragon
5,325
still plugging away, all the ribs designed except tip which I realized has a skid attached, so need to re-think the concept for it. Ordered and received 23 ft. aluminum in a roll, decided I did not want to splice my spar webs.
Got to start thinking about tables too, 22 ft of them, Guess if I was younger I could work on the floor, but that is no fun.
5,325
Tip rib, with skid, and counter-weight. Probably will have to keep skid in clecos to assemble and line up the wing. Should have seen the first monster....this is the less complicated edit....
5,325
First of many tables for wing assembly. Modified EAA table. 2'x4' Has adjustable feet for matching the tables and level and flatness. I do not want to unroll my 23 ft. roll of aluminum to get more material to finish the ribs without the tables.
5,325
Got 6 tables done, reviewing the wing assembly and it looks like 6 may be enough, but I have enough material for 2 more tables. Currently mounting lights, re-arraigning stuff to make room. Should have some pictures of the setup in a couple of days.
5,325
Ready to cut.....and Spar Webs front and rear, cut rolled and stored under table. I try to make paper templates from the CAD for everything, I find I make less mistakes than when I lay things out.
5,325
Third and Fourth rib from the tip RH and LH. Plot of assembly and flat patterns. Paste to aluminum (just bought 1 qt of rubber cement) and cut, line in middle is bend line. Holes are in the top pieces of the assembly for drill through at assembly after mounted in the jig. The plotter is within .01 and on 100% rag Vellum it is very stable. The pen plotter is better than my printer, but for small parts the printer would work ok. It is easier to keep the parts straight if I plot them all for any rib on one sheet. The only problem I have had is it is best to wait 12 hr for the glue to dry, as the vellum does not allow air through much.
5,325
Switched to #4 finishing nails into soft pine for my rib fixtures.....It was easier to locate on the edge of the line, they drove in easier than the drywall screws. The soft pine works better than ply because it does not splinter and is softer.
5,325
I was able to talk a local mechanic into letting me use a very old bending brake he was not using. It probably is from the 30's it is massive but for perfection sake would need major re-work. My existing brake was rated for 22 ga (1/32) but the 4 ft. .025 hardened material was not bending straight and was very hard to bend. I had to use a pipe on the handles. Any slight variation in radius along the bend will cause a bow. The existing brake was flexing in the middle. All of these style brakes flex in the middle. Also often the middle is more worn. Even the big brake did not bend straight but the larger pieces were better and easier to bend. The smaller ones have a large bow. On these pieces it is not much of an issue because they will be straightened in the fixturing of the assembly and looking at the picture with the small clamps they straighten up easily.
The big issue I was concerned about was the Trailing Edge, as there is a long distance between the Warren Style Ribs. However I was able to get it straight with the fluting pliers. It will be fabric covered so the flutes will not show. All in all it is going nicely, I have to cut out parts on the rest of that 23 ft. sheet so I can use the table to begin assembly of the aileron.
IMG_20180508_073245.jpgIMG_20180508_095228.jpgIMG_20180508_095344.jpgIMG_20180508_095619.jpgIMG_20180508_095649.jpg
5,325
Got so tired of making ribs decided to cut up all the material for the rest of the ribs on the roll and the last 4 ribs (8 LH and RH) will be assembled as fill in upstairs in the small shop. I will hopefully start the assembly of the full span aileron next week because I will have the long table cleared off.
5,325
The parts keep adding up,....starting setup for aileron....sort of like a big model, paste the wood over the plans, except it is aluminum.
IMG_20180522_173229.jpgIMG_20180524_130337.jpgIMG_20180524_123937.jpgIMG_20180524_122323.jpg
5,325
The 100% rag paper was not stable enough for 22 ft. of drawings....worked for the details but that was just too big, wrinkles bad dimensions. I ended up plotting on Mylar, and that looks much better. I am able to hold 1/64 over the whole 22 ft. and I am not sure if the tape measure is that good. Several minor changes to the design had to be made.....It looked good on paper so they say but when I saw the assembly I changed it. Riveted the splices on one long piece, and got my hinge material from Spruce.
5,325
Farther along with a now almost hard tooling assembly fixture....notice the wedges on the spar mounting for that 8 degree tilt. Was into the 3d model to find where the trailing edge is flat.
5,325
All drilled....not perfect, +- 1/8 on the trailing edge,...lets hope the slow speed it will not matter....that's what trim tabs are for. Next take it apart, deburr the holes and rivet. Might even have to add more ribs as between the hinges it may not be stiff enough. The trailing edge is "very structural" and carry the loads back to the spar through the "Warren Style" ribs. Note laser dot on hinge...the hinge line is within .05.
5,325
Pictures later... does not look much different finished from posted pictures,.....just finished riveting..... the assembly with ballast counter weight totals 7.72 lb
