Alternative leading edge material?
karmarepair
Jan 13, 2011
441
United States
Some possible LE materials, comparing the elastic modulus (stiffness) and density:
Modulus, MPaDensity, gm/cm^3
Polypropylene1325.92
Polystyrene32501.05
Acrylic (plexiglass)28551.185
Aluminum690002.70
Wood12000 - 16000 depending on species.5 - 1.1
Me, I think I'd try the Polystyrene first. Cessna wingtips since Jesus was a Airman Recruit. You MIGHT have to heat form it, which would be a PITA, since the temperature difference between Formable and A Sagging Mess is about Not Much. Better if you can find it thin enough so it bends as easily, and probably in the elastic range, as .016 aluminum.
I also thought of laying up fiberglass or carbon on a sheet of glass, then wrapping it while it's still "green", then post curing, but that sounds like a lot of bother.
And the leading edge cover needs to be stiff enough to hold the shape, but not so stiff that it tries to take the primary bending loads, unless it's DESIGNED to take the primary bending loads as a D-Cell spar....
8,451
This thread seems to have opened up the proverbial can of worms!
I agree with the idea that nailed-on aluminum as per the VP-2 plans (which also give a 1/16” plywood option) is the easiest to do, the toughest part is carefully locating and perhaps predrilling the holes with a tiny bit so the nails don’t split the ribs. I am intrigued by the batting solution to reduce or hide dents.
After that the plywood seems like a good option. I could see skipping the scarf joints in this non-load-bearing application and just butting the sections together over a rib, perhaps with a little epoxy and a single thin strip of fiberglass to reinforce the joint.
Bill-Higdon
Feb 6, 2011
1,376
Salem, Oregon, USA
Or make the rib under the joint under size enough to take a strip of plywood to meet the proper regulatory guidance.
8,451
Thanks for that, very helpful, here's the one where he starts putting the plywood leading edges on the wing.
One question I have is that on something like the VP-2 the leading edge wrap does not end on the spar, it's unsupported between the ribs. The plans say to put a crimp in edge of the aluminum wrap between the ribs for rigidity. Would 1/16" plywood need any additional support and, if so, how would you do that?
Makes it look doable.
Bille Floyd
Sep 26, 2019
490
In many fabric-covered, strut-braced wing designs, the leading edge wrap is there primarily for aerodynamics.
Anyone have any experience with something other than aluminum or plywood in this sort of application?
Lifted a set of D-tubes, made from 3mm Nomex honeycomb, and Kevlar
that did not need to carry any twisting load ; could pick up both, with
one hand, and the arm extended out straight. They were for a 40' span
hang glider.
I beat the weight of those kevlar D-tubes, with samples that were made with
1/4-oz carbon mat, which gave much better peel-shear from off the 3mm Nomex
and (1) 3K tow, +/- 45, of Carbon each lnch, and a 1/4-oz Kevlar mat on the outside
to help carry the puncture resistance between the 1/8" nomex cell, (it was Really light).
Need to build for a twisting moment ? Add more 3K carbon towes , to the same matrix.
Bille
n45bm
Feb 20, 2019
127
Seguin
Another off the wall idea:
Cardboard - of the single sided variety.
Dip in thin West System, drain, drape over form (smooth side out), let cure.
Something similar was tried by Molt Taylor. He talked about fiberglass reinforced cardboard, I think.
Aesquire
Jul 28, 2014
2,854
Rochester, NY, USA
A mylar or foam or??? sheet is often inserted in a "pocket" ( actually double layer of fabric sewn on 3 edges ) to stiffen the upper leading edge of hang glider wings, just to smooth out the sag between ribs. The mylar is a bit prone to fold creases, so my old Duck used a foam sheet. Current high performance gliders use a combination of heavier material and multiple layers often with multiple materials all sewn together.
Keep in mind the leading edge upper reinforcement is not all that rigid, it has to roll up when you fold up the glider, but the conical curvature ( on a tapered wing a long trapezoid ) adds remarkable stiffness in the other direction.
One of the problems with composites in thin wall applications is the material strength of the fibers, Kevlar, or cardboard, isn't a lot of help in dents/breaks at right angles to the surface, that becomes more a matter of resin properties.
Grumpy Cynic
7,851
That would be TPG.
_______________________
UUUUUUUUUUUUUU This kind of single sided cardboard has much greater "I" (stiffer) than 90# liner board but can still be bent easily in one plane. It - might - be less dent prone than the typical aluminum LE material?
Richard Roller
Feb 15, 2018
66
Olathe, Ks.
What is the rib spacing on your a/c project? The Piet I fly is about 11". There is little sag between ribs caused by the fabric shrinkage, very minor. I'm not familiar with the mini-max, I was surprised at the large rib spacing.
8,451
VP-2 wing ribs are spaced 8-12"" on center with most at 10".
14,968
With something like a MiniMax, every ounce might put it over. You are building bare minimum. A Piet is a much sturdier airplane.
starrtit
Nov 1, 2020
31
Hot Wings has a VERY valid point regarding cardboard. I am reminded of the great advances that have been made to this simple medium every time I open a new case of beer. It also brings to mind the designer [name slips my mind] with a pusher who advocated very thin
F/glass to cardboard as an excellent material.
Grumpy Cynic
7,851
Thinking of the Taylor Micro Imp?
Cardboard for aircraft construction is, IMHO, kind of in the same situation as electric power. It can work in some limitited applications but still needs a lot of innovation/discovery before it can be really viable.
14,968
The issue with cardboard is lifespan and it’s heavy if protected from elements. I have built cardboard RC planes and they can be fun. If you varnish the cardboard for protection, you have two glues; one glue holding the fibers together and then a second to protect. Double of something you want one of. Waterproof cardboard that is not waxy or glossy that you can cover with airplane covering. It can’t be able to absorb water. Wash, rain, or humidity. Cant rot or mold easily. Starting to ask for a miracle material. It would be well known if it was out there.
mcrae0104
Oct 27, 2009
3,931
KBJC
If we're considering "disposable" materials, why not get all Sripol on it with foam & aluminum tape? Not very tough, but cheap and easily repaired.
Latest posts
