Ag-PIG 194
Discussion in 'The light stuff area' started by inventing_man, Aug 24, 2009.
  1. Aug 13, 2010 #21
    inventing_man
    inventing_man
    inventing_man
    Aug 30, 2008
    108
    0
    Thanks George ,Yes I know . Hope he has good luck with it ,, and it flys OK! A good flight report will surely spur me on with this gig.
  2. Oct 2, 2011 #22
    inventing_man
    inventing_man
    inventing_man
    Aug 30, 2008
    108
    0
    bloop Its flying with Ok results so far with a 2 stroke .
  3. Oct 3, 2011 #23
    pwood66889
    pwood66889
    pwood66889
    Feb 10, 2007
    1,489
    162
    Sopchoppy, Florida, USA
    Thanks for the Bloop update link. I have been following Mr. Sandlin's work for some time and had missed that. Of course, the fact that it was posted today...
    And where `bouts you at?
    Percy in SE Bama
  4. Oct 3, 2011 #24
    inventing_man
    inventing_man
    inventing_man
    Aug 30, 2008
    108
    0
    Me ? I'm SW Missouri . Sandlins climb rate was at 290 something . Not bad , But he weighs next to nothing a well .
    I'm trying to up the performance / safety using a V twin and a 64 inch prop . And a nose wheel too. :gig:
    If I do this right And make a Main frame for the motor, gas tank and redrive, plus the pilot seat, controls and nose wheel . Basiclly what I will have is a common Trike Frame that are used between Delta and PPG wings . It looks like this frame will be able to do 3 different wings , fixed wing Glider, weight shift delta and PPG. I'm making the brackets so that each configuration is a simple matter using the compression strut mount and the hang mast tube mount as common features between them all. In the realm of this kind of frame
    [​IMG]
    But adaptable [​IMG]
