Aeromarine VTwin now in Electric Hybrid Version
PagoBay
Nov 16, 2013
336
US Territory of Guam
Welcome Hybird — New Four-Stroke Engine for Light Aircraft; Replaces HKS
Daleandee
Sep 11, 2015
1,567
SC
I watched this video yesterday. Seems impressive enough ... but seeing a bunch of them flying would help!
Niels
Aug 15, 2019
139
These kind of short ,big diameter electric machines can be a very good solution to torsional vibration problems.
One at each end of a 6 or 8 throw crank will tame it for very low mass.
Wild Bill
Dec 11, 2013
109
Vidalia, GA
I saw that. Looks promising.
I’ve never thought of converting a SxS motor.
I did some reading and it looks like many of the SxS vehicles use a Rotax V twin engine. (HD-8 and HD-10)
If you look at those engines they at least appear identical.
Would be great if Rotax would just make a version of this engine with their redrive for AC use.
sharpvector
Jul 25, 2014
18
Monona
So I wonder what the idea is here. Does the V Twin charge up a battery for running the 40KW BLDC motor? Or does the electricity for running the BLDC motor come directly from the V Twin itself?
Grumpy Cynic
7,976
Maybe the moderators could merge these 2 threads - then delete this post?
Both seem to be abut the same engine/motor?
8,812
Until the controller glitches out. Then you are likely to break the crank.
