With a few electronic ignition systems coming along something needs to be said. If you use coils with 2 high tension leads, IE. floating secondary, you must note that one plug fires normally and the second plug fires backward. This can cause problems if you use the fine center wire spark plugs. (Automotive) The plug that fires backward can ruin the center electrode in just a few hours. This is not a problem if you use coil on plug coils and just switch the low tension primary, the coils function normally. Motorcycles have used multi-lead coils on the 4 cylinder engines for ages even in points ignitions. (Back when dinosaurs ruled the earth) They waste a spark in the exhaust stroke. One coil triggered every 180 degrees.
Bill
