Rad 123, I have just completed a Spread Sheet, it's short and simple, jut put in your proposed Span and Wing Area and automatically, does a lot of things for you like confirming Wing Area, Ht and VT area with lever arms, with lever arm adjustment for comparison with standard Volume coefficient, with all formula provided. You can take the new Wing Area answer and manually reenter that into the program until you get the ability to both adjust either or both the Span and Wing Area until you get a more accurate result - in the event your original entries were unrealistic.
I did this for my own benefit as I was wanting to easily define all these parameters with the minimum of entries and adjustments.
If you want this it's an Excel file, just post me privately and I will sent it to you with a copy of my Tandem design, you might get ideas of what I alluded to with changes to the tail.
George
George
